I thought I had entered my location, trailer and TV info but I guess it didn’t stick. Surely it wasn’t newbie user error. I re-entered it and hopefully correctly those time. I’ve got no illusions on having a towable mirror and only wanting to made the trailer presentable. I wished I had stripped the clear coat years ago when it first started to fail. The corrosion under failing clear coat is much worst that the gray patina you get from bare aluminum.
I ran across a posting saying the Alcoa clear coat could be removed with 3 or 4 applications of ZipStrip. I found some at a local hardware store but have yet to try it. It does contain that chemical that all the other eco-friendly strippers brag about not having so it might work. The few other posts I’ve found say it can’t be stripped or it has to be sanded off.
If the a way to reasonably match the Alcoa finish I’d be more that happy to go that route and leave those panels alone.
My results so far have been mixed. The 8 year old Removal 220 is working but requiring multiple applications. The Citristrip seems to work better but leaves a hard to remove residue.
From left to right Citristrip after some cleaning, Citristrip after just a water rinse and then the shinier Removall 220 results. A wet Magic Eraser seems to work best on the Citristrip residue but I really would prefer it cleaner before I start polishing. Any suggestions?
