Old 07-29-2008, 07:07 PM   #1
las vegas , Nevada
Keeping it cool!
Hello,
my mom has a motor-home and we cannot get it below 80 degrees here in the summer in las vegas. Can anyone offer some suggestions please?
Its a 30ft, Winnebago Itasca motor home, model Sunrise, year is 1999.
What has been done to keep it cool so far...
Solar Screens, silver air bubble sheets placed on windows between glass and curtains. A/C (2 yrs. old) on lowest setting (not enough), awning is out, parked with some shade, doors & windows kept closed, shades drawn.
She is getting older and I have concern for her fluid balances and heat exhaustion.
Should we install an additional window AC unit or an swamp cooler, if so any recommendations on a unit and or installation?
Would a fan help, or opening one of the ceiling vents, geez just any help or small suggestions would be much appreciated.
thank you,
Bill
lasvegas1 is offline   Reply With Quote
Old 07-29-2008, 07:34 PM   #2
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Hi,
Maybe you should consider adding a second roof A/C towards the rear.
Also make sure the roof top A/C has been serviced and it operating normal.
NO Window Unit.
Good Luck.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-29-2008, 07:49 PM   #3
cameront120's Avatar
1972 25' Tradewind
Do the roof vents have fans that can draw the warm air up and out? On my trailer there is a huge difference in interior temperature with the front vent fan turned on and the rear vent open. The fan draws the warm air out and keeps the interior temperature reasonable.
North Vancouver, BC
Old 07-29-2008, 08:04 PM   #4
las vegas , Nevada
Humm, why not a window unit what are the pros and cons? One of her concerns is that if there are two units the wiring in the home would fry up, and the load could not be handled...?
Old 07-29-2008, 09:14 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Swamp cooler (evaporative cooler) not recommended unless the humidity is usually low (which it might be in your area)...high humidity renders them pretty inefficient.
TB & Greg and Abbey Schnauzer
#3954
Old 07-30-2008, 03:20 PM   #6
las vegas , Nevada
Cameron,
yes, it has vents to pull air out, but my concern for her is that i would pull out the precious cool air as well.
TB & Greg,
yes its pretty arid here, no worries of it being humid, in regards to a swamp cooler. I just don't know what the pro's and con's are with an additional ac unit versus a swamp cooler.
Greg,
why not a window unit for an ac...and would a swamp unit be okay in the window?
thank you very much,
Bill
air conditioning, cooling, hot
keeping rv cool during extended parking jagcb750 Classic Motorhomes 29 10-02-2011 08:58 PM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 09:20 PM
How are you all keeping the shine Angel73 Cleaning, Stripping & Polishing 7 07-26-2006 10:24 PM
South Keeping Cool While Boondocking rseagle Boondocking 5 03-26-2006 12:09 PM
Keeping refrigerator on mcostanzo Refrigerators 5 04-16-2003 08:14 PM
