Old 10-19-2018, 02:57 PM   #1
Clifton Park , New York
Just joined the forum!
Hello,
I just joined this forum, hoping to get ideas about eventually buying and owning an Airstream travel trailer. I have been doing some research and I am looking at the Sport 16RB. My tow vehicle is a 2018 Honda Ridgeline, and this is about as large a trailer it can manage comfortably. I'd appreciate any comments from members of the forum about their experiences with this particular model.
George
gpascual is offline   Reply With Quote
Old 10-19-2018, 04:00 PM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
No experience with that model but welcome.
GMFL is online now   Reply With Quote
Old 10-19-2018, 04:20 PM   #3
Wrangler's Avatar
2019 19' Flying Cloud
Renville , Minnesota
Welcome, George.
We looked at the 16’. We decided that we liked the 19’ FC layout better. Fortunately my tow vehicle was adequate for the additional weight of the 19.
I currently camp in a 19í Flying Cloud towed by a Nissan Frontier.
Wrangler is offline   Reply With Quote
Old 10-21-2018, 07:14 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado: Always nice to have new folks join these Airstream Forums. You can learn all about the Sport 16' and what folks are using to tow it with. The new Ridgeline is more truck like than the earlier generation. I read it is rated for 3500 pounds with 2wd and 5000 with 4wd. I don't know what type of receiver is bolted to the back of the Ridgeline, but I would want a Cat 4 receiver with the standard 2" square shank mount. It also needs a 7 pin connector and a trailer brake controller. Maybe you already tow a trailer with this vehicle?
There are other factors to consider too. One is the "gross combined vehicle weight rating", the cargo weight rating, and the weight rating for the Sport. Airstream and others publish the "dry weight" of their trailers, but then you fill it with water and propane and a week's provisions and the weight is not several hundred pounds more. Same with the Ridgeline. So consider the "gross" weight ratings in your thought process. The tongue weight of the Sport might be up to 500 pounds that the Ridgeline has to carry.
Welcome here. You can search on the Sport model as will as the Honda Ridgeline and read some threads on what people's experiences are.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
dbj216 is online now   Reply With Quote
Old 10-22-2018, 08:22 AM   #5
David,
Thanks for the information. My Ridgeline is rated for 5000lb, and has a transmission cooler. I'm pretty confident that it will tow the 16RB and whatever I need to pack into it. The tow package was factory installed with a 2" hitch and 7-pin electrical connector.
Cheers!
George
Old 10-22-2018, 08:48 AM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If you have a talk with Andrew at Can-am RV in Ontario Canada, you'll will find that with some modifications to your hitch, your Honda Ridgeline will be able to tow a considerably longer trailer comfortably.
Give them a call first to get your options BEFORE you pigeon hole yourself into a trailer you may not like.
Cheers
Sidekick Tony
PS He has Honda Odyssey's towing 34' tri axle trailers
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 10-22-2018, 09:39 AM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us. Your Ridgeline may do the trick. You will just have to try it and see. Since you already own the Ridgeline, you have nothing to lose.
You will need to purchase and install a trailer brake controller in your Ridgeline. This is an absolute necessity as the brakes on the trailer will not operate without this. You will also need to explore the various weight distribution/anti sway hitch systems. This is also something that you are going to want. Pulling a heavy trailer with a light tow vehicle can become quite uncomfortable without one.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 10-24-2018, 11:45 AM   #8
Tony & Brian,
Thanks for your recommendations, guys. I have reached out to Andrew at Can-Am RV, and will see what he has to suggest. As for the trailer brake controller, there appears to be several available for my tow vehicle. Any recommendations? I will definitely add any accessories necessary to make towing the trailer safer.
Cheers!
George
Old 11-01-2018, 08:20 PM   #9
2017 16' Sport
Nashville , Tennessee
Hi George -
I just sent you a lengthy PM but I’m not sure it went through. I have a 2017 16’ Sport that I tow with a Hyundai Santa Fe Sport (after getting CanAm’s blessing Let me know if you get my PM OK?
Warm regards -
Holly
HollyBee is offline   Reply With Quote
Just Joined Ed Emerick Member Introductions 6 07-16-2006 03:37 PM
Just Joined, Just Started a Full Restoration HamiBambi Member Introductions 10 07-06-2006 08:25 PM
I just joined the forum zippy Member Introductions 2 04-11-2006 03:59 PM
just joined oldwingrider Member Introductions 9 04-05-2006 06:48 PM
