Old 03-14-2006, 12:09 PM   #1
duojet's Avatar
Nashville , Tennessee
Just got a '73 Overlander. Now we need a tow vehicle!
Hi. We're new to the forum so we just wanted to say hello.
Hello.
We recently obtained a '73 27' Overlander from a family member and are just beginning to look for a tow vehicle.
Any opinions?
(I'm about to seach the forums for this subject so forgive a newbie's impatience!)
Thanks.
Jordan
duojet is offline   Reply With Quote
Old 03-14-2006, 12:51 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Let me say welcome.
Welcome.
No need to search - the right answer is Suburban C20. Or a Silverado 2500.
Tom
Old 03-14-2006, 01:53 PM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Well I might be a little biased here but there's something special about an Overlander and a Hummer H2 (IMHO)
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 03-14-2006, 01:58 PM   #4
canton , tx
Welcome and good luck on your search for a tow. I love my Nissan Titan. joe
rvlover is offline   Reply With Quote
Old 03-14-2006, 02:26 PM   #5
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Welcome and nice to have you on board!!
You´ll probably get as many different opinions as there are potential Tow Vehicles... So good luck, when filtering and evaluating the data you´ll get.
You should try a search for Tow Vehicles by the Search Function of this page and if you want some informations on Gasmileage this could be a thread fro your...
Take C'air
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 03-14-2006, 05:37 PM   #6
bill benton's Avatar
Mansfield , Texas
Most any _ _ _ _ will do
Ford that is. Most any full size truck or SUV with a large motor will do.I'm partial to Fords. F150s, Expeditions, F250s, Excursions will all tow it. Just check the weights. I have even seen Airstreams towed with other vehicles.
bill benton is offline   Reply With Quote
Old 03-14-2006, 05:39 PM   #7
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Oh, let us not forget the Tundra folks on here.
juel is offline   Reply With Quote
Old 03-14-2006, 05:54 PM   #8
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Welcome aboard ! )
First of all, you want to know the weight of your trailer so you can choose the right truck for you. The guys are right, a 2500 Dodge, ford, Chevy, GMC, Titan (oops, they don't make a 2500! hehehe), is the way to go. If not, check the weight the each can tow. Diffiently get one with a tow package!/V8
Rear end is also an issue, 3.55/392, 4.10 etc.
Well, enough of my 2 cents. Once again, welcome aboard! may all your trips be safe ones!
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 03-14-2006, 06:08 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome, and I'll second what everybody else said about a tow vehicle. Your Overlander should have a GVW (msax weight) of around 6000 pounds, so look for a tow vehicle that will tow at least that much, and preferable about 20% more, to be on the safe side. We tow our Overlander with a Chevy 3/4 ton van with a 6000 pound tow capacity, and there are times I wish we had a little more than that.
Old 03-14-2006, 06:53 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Hello.
Any opinions?
Thanks.
Jordan
Jordan,
I suggest a 1973 Dodge W200 PowerWagon, it is the same year as your Overlander.
Bill
Just my personal opinion
Old 03-14-2006, 08:53 PM   #11
Frank S
peoria , Illinois
1973 Overlander 27' Tow Vehicle
Hi Jordan--We have successfully towed our 1973 Overlander 27' with a number of 1/2 ton, 1500 series, Chevys, all with success, since 1988, when we became its 3rd owner. Florida, Midwest, Eastcoast, Colorado, and all points in between. The beauty of the vintage 27'er is that it only weighs 6000 lbs. light by modern standards as it doesn't have oak cabinets and all the extra stuff they load in now. Started with an '89 Beauville window van 5.7 & 3.73 rear, OK, but a little lacking. Next a '91 van 5.7 & 4.10 rear, much better. Then a '95 followed by a '97 Suburban 5.7 & 4.10, really liking it now. But best of all a '01 Suburban 5.3 & 4.10, with the 4-speed auto trans with Tow Haul, which is a perfect balance for 1973 Overlander 27'. You should have a trans cooler, and a load equalizing hitch. All of the 4-speeds have a 3.06 first gear which is low enough to get you started anywhere. I always tow in 3rd gear which is comfortable at 70 mph and average 9 mpg. Without the trailer, in 4th gear I get 16 mpg highway, and 13/14 around town. The ride, handling and 16" tires of the '01 is a marked improvement over the "95 & '97. Tahoe is also a consideration, but few if any have a 4.10 rear, you might as well have the extra space of a Suburban for the same price and they aren't any harder to drive or park, and will fit in most garages. '00 thru '03 Suburbans came with 3.73 or 4.10 rear, while '04 thru '06 have 3.42 or 4.10 (I may be a year off on the switch). You don't want a 3.42. Of course a 3/4 ton 2500 suburban will do a better job towing, however it rides rougher, and uses more fuel. Unless you plan to cross the rockies a lot, the 1/2 ton will work just fine. The '01 I have is the only one of the bunch that has 4-wheel drive which I have never had to use, even in MN snow. I got stuck twice with some of the other suburbans and the trailer on soft grass in a flat area. A couple of boards under the wheel, and I was out. I know you will enjoy your 27' Overlander. It's small enough to tow with ease, and big enough to live in comfortably. Good luck on your towvehicle selection. Frank S
Frank S is offline   Reply With Quote
Old 03-14-2006, 09:00 PM   #12
Frank S
peoria , Illinois
Old 03-15-2006, 04:05 PM   #13
duojet's Avatar
Thanks for all of your replies. We're kind of leaning towards an older Suburban diesel. If anyone has any leads, please let me know.
Thanks again.
Old 03-16-2006, 10:36 AM   #14
Frank S
peoria , Illinois
Hi Jordan--Would go slow on acquiring an older used diesel as a tow vehicle, if you haven't had a diesel before. I didn't see any mention of diesel in any of the responses you received, maybe for good reason. Used diesels usually have worked hard, which is why originial purchaser went the extra money for a diesel in the first place. Diesels are louder, smellier, require more expensive maintenance, and are quirkier. Talk with some people who own the brand you are considering, and some mechanics before you commit. If you are considering diesel for fuel economy, forget it. If you travel 15K miles/year, and fuel cost $2.30/gal, the difference between an average of 15mpg and 20mpg is just $575/year. This is small in relation to the real costs of tow vehicle ownership, which are maintenance, repair, and the big one, depreciation. Good luck with your quest. Frank S
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
