Old 07-13-2008, 11:40 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Just brought an Airsteam
All--
Just bought an 75 Safari (23ft) and now puzzling over where to start. That said, it has virtually *no* dents on the outside. Woo-hoo!
Now the things we need to fix...
1. Bathroom is scary
2. Again... the Bathroom is really scary
3. One of the POs loved contact paper
4. One of the POs had apparenty a case of silicone sealer lying around
5. A PO cut hole for a deadbolt to the right of the door
6. The wiring is a bit on the "oh my gosh" side of the line
7. None of the tanks have OPD
8. The "new" RV battery is 2 years old an appears to have been fried
9. The front window leaks... or did, can't tell due to all the Silicone
10. The Land Yacht plate on the port side is missing
... Oh, and the door handle broke on the first day of ownership
But I'm now a Airstream fixin' member of the "club".
Ron
ronstory is offline   Reply With Quote
Old 07-13-2008, 11:53 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
First of all, welcome!
It sounds like you have your work cut out, but the makings of a nice trailer.
Spend some time in the restoration threads, there is a ton of info about some of the things you need to look for. With the water leaks, floor rot may be one of the main things you'll have to address.
Good luck, take photos and post them here, keep us updated.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 07-14-2008, 05:39 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You may find the dead bolt hole is for a factory deadbolt, as they could come with them. Batteries are relatively cheap, but you should take a look at what is charging it before blind replacement. We had a Univolt that worked great--when we didn't need it.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 07-14-2008, 11:10 PM   #4
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Terry--
Do you have any idea of where the dead bolt went on the original config? Was it mounted in the door or on the wall/bulkhead side?
Ron
Ron
Ultimate Airsteam Phonograph rideair Off Topic Forum 0 12-11-2007 10:47 AM
brought my 63 globetrotter home today 1963gt Member Introductions 16 05-30-2007 12:12 PM
we just brought home our 1959 Traveler! cindychalled Member Introductions 6 11-28-2006 04:26 AM
Brought home the 1978 31' today - thanks Coastalview! kramynot2000 Our Community 10 09-18-2006 08:51 AM
Airsteam restaurant help burger Plumbing - Systems & Fixtures 9 10-06-2005 10:16 PM
