Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 01-12-2006, 08:56 AM   #1
sierrajb
sierrajb's Avatar
Profile:  1975 24' Argosy 24
Fort Worth , Texas
Is My Dream a Nightmare?
Hi, all...I am heartbroken, sick to my stomach, depressed, scared...you name it. I feel like someone might feel who searched all his life for the perfect mate, married her, then 10 days later he discovers she only has a few days to live. Here's my brief story...
My previous post, "It's Official...Airstreamin', not Dreamin" tells of my discovery and purchase of our first, brand new (to us) 1967 International Overlander. I've even posted some of the pics of this dream craft. At the tiime of first viewing this AS I noticed the rivets had gone from the trim around the wheel opening on the streetside. Looking closer, I could see the aluminum somewhat slightly crumpled, wavy, or bulky. The curbside seem acceptable: No missing rivets, but slight waves just above the wheel opening. My estimation was that once the rivets on the streetside were replaced it would take out the waviness and crumpled look on that side. I WAS WRONG!
My mind quickly searched all the things I had read for months on this forum. I could only retrieve topics like "tail droop, rear end separation, tail sag...etc." Many of you already know where I'm headed, don't you???
Almost instantly I felt sick to my stomach. I had just depleted my family's savings PLUS took out a small signature loan to pick up this jewel. Now, from what everyone says, my AS has a bad case of tail end droop, separation, whatever you call it. I'm almost 100% sure that's what's causing the crimpled look on the sides around the wheel openings. Now, all of a sudden, it makes perfect sense when the previous owner used 3 cans of expandable foam in the rear storage compartment that houses the waste tube, etc. I thought is was for insulation purposes or keeping out unwanted field mice, etc. What a retard I was!!!
I know. I'll get a whole host of you saying, "Don't be so hard on yourself. It's still a good deal. It's a sweet rig and worth fixing. It can be repaired. It'll take a few thousand dollars, but when you're finished, you'll have a classic AS that's top of the line and beat out every other trailer on the road." And I would agree.
However, the bottom line is I'M OUT OF MONEY! I can't afford to jeopardize the financial stability of my family by sawing off the limb we've already crawled out upon. My options? I guess sell it to the highest bidder and hope to get everything I put into it. (I JUST purchased $500 worth of replacement parts that would make it really cherry!).
Thanks for sharing this "buyer's remorse" with my family. I'll let you know the date and time of the funeral.................
sierrajb is offline   Reply With Quote
Old 01-12-2006, 09:27 AM   #2
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Whoa Cowboy!
Slow down, don't jump to conclusions. A couple of things -
1) Your unit (aside from a few bumps on top) looks fairly complete and clean. You were looking for the most turn-key vintage trailer out there. Unfortuneately, it's a bit of a fact that almost anything 20-30yrs old will need some fixing.
2) I don't think the early year AS's had much of a taildrop history- this was mostly the 70's era trailers with the rear bath and grey and black tanks. All that tank weight back there wasn't good for the frame rails. I think you only have the black tank, right? While your trailer did spend some time in Fla, I don't think rust would be too much of an issue being most of the time in Tex. I think the foam was for rodent, cold abatement - however, I'd poke the wood under the sink cabinet (if you can get to the floor) to check for softness. Not sure how it would cover up a separation. However, the rear of these AS's are notorious for leaking.
3) Try these tests. Have your kids (or wife) go into the bathroom - this will be a fun time for them. Have them jump up and down in there, while you walk around the rear of the trailer. IF there could be separation, you'll see the rear of the trailer flex up/down vs. the middle of the trailer (viewed from the side), or the buckles and waves move. From the rear, you should see the bumper/compartment move up/down, and possibly the rear shell not move. Most of the cracks in the frame are visiable right around the axle frame area. Look at the frame visiable, and look for cracks. You are a body man per trade. The reinforcements / fix (look in the forums for pics) is just a L-brace welded onto the frame - you should be able to either weld it yourself or have someone do it for you for fairly cheap.
4) Your problem may not be the main frame rails, but rather from outriggers that separted off from the main frame. (Search "this is going to be expensive" by steph roberts). Uwe may chip in here and tell me if I'm off base or not.
5) The rivets may of sheared from a wheel imbalance problem.
5) Photos speak a thousand words - can you post some?
PS - I think you need new yellow clearance lights for the top of the trailer (front). Teardrop ones would look cool!
I think you have a great starting point. I wouldn't sell and start over - I know money is tight, but honestly, almost any vintage unit will cost additional money in repairs. If the systems are working (water, fridge, AC, electrical) and had been replaced currently, that's some significant money ahead of the game. All of these systems WILL have to be replaced some time in the trailer's history. If you can get it rolling safely, it looks like your family can use it as is. A lot of us could not say that (I couldn't really use mine for about a year) when we bought our trailers.
Take care,
Marc
Old 01-12-2006, 09:44 AM   #3
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
From all I've read, a 26ft of that age is not prone to the rear end problems of the longer 70's coaches. You may have a cracked frame from the trailer hitting a pot hole. I had that with my 67 17ft Caravel after dropping into a hole in the road. I simply took it to a welder and had a piece welded onto the frame. From what I know, it's still going strong. Don't panic yet.
juel is offline   Reply With Quote
Old 01-12-2006, 09:56 AM   #4
desi arnaz
desi arnaz's Avatar
Profile:
why don't you get some people from your church to give you a hand? bring it up in your next sermon.
desi arnaz is offline   Reply With Quote
Old 01-12-2006, 09:57 AM   #5
Jim Jarzabek
Commercial Vendor
Jim Jarzabek's Avatar
Profile:  1950 25' Cruiser
Lebanon , Ohio
Images: 16
Inspect before you pay...
Not to sound harsh, but your profile lists you as available for trailer inspections... That being said and carefully reading your post, it appears you have the same problem occurring around both wheel openings.... I did not read your previous original post you referred to, but who you purchase from is equally or greater than what it is you purchase - Airstreams or anything else. I recently received a couple messages from a Forum member who purchased an Argosy & apparently paid in full before Christmas with no delivery yet. She was freaking out. Whatever you are having problems with was there most likely before you purchased this. I don't think "Buyer Beware" applies as much as "Buyer be Informed". I sympathize with your dilemma but don't make it worse by acting now before you inspect. There is good advice in the two previous posts & I would follow it.
Good luck!
Jim Jarzabek is offline   Reply With Quote
Old 01-12-2006, 10:10 AM   #6
rebel beck
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
Take it with a grain of salt.
I'm a newby to but all Ive read hear is the tail droop run's in the 70's models like prev. stated. The reason we bought vintage was because they were a whole lot cheaper than a new Airstream and made a whole lot better then all the new other brands.
We to ran into some problems the prev. owner failed to tell us or he didn't know (ha ha) But we also knew when we started looking at these older models we were going to run into problems. So what we do we take them on one at a time and my family understands we may eat beans for a few day's in order to get a new piece of plyboard for the floor that week.
We also learned there are alot of things you can learn to do in order to save money, like putting the floor back in and not hiring it to be done.
Don't give up, I was at that point last week when we found out about 4ft of our floor was rotted out, but after chatting with the folks here I felt much better and we are on the way fixen that floor.
Becky
rebel beck is offline   Reply With Quote
Old 01-12-2006, 11:46 AM   #7
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Slow down, do a little inspecting, and if worse comes to worse, just sit on the project until you can save up the money to do it right. I did a complete floor replacement on the front half of my trailer, and the actual cost was about $500 with me doing all the work except for the welder I hired to fix the frame. It's not easy work, I won't lie about that, but it's certainly do-able. I think my previous car restoration experience enabled me to take it all in stride, as you should too. Your trailer is 90% good, so don't let that 10% frustrate you too much.
I also had the knot in the stomach when I first discovered my problem, but we worked through it, and now it's good as new and ready for another 35 years on the road. Yours will be too. Don't be too quick to pass it off to someone else!
Stephanie
Our family photo blog
Old 01-12-2006, 01:20 PM   #8
sierrajb
sierrajb's Avatar
Fort Worth , Texas
Breathing Easier Now!
First of all, if I could start an "Airstream Support Group" at my church I probably would. Also, if I can drop a biblical hint or two in one of my sermons....I just MIGHT (ha! )
When I first inspected the trailer I did the "jump up and down on the rear bumper" method. I could see the bumper separate no more than 1/2" on either end, less in the middle. I weigh only 165 (give or take a few oreos), but thought that would have been enough weight to provide a good test. My offer of inspecting other trailers in my area is genuine, but limited, and certainly NOT PROFESSIONAL. I had a fine man and his wife help me turn down a trailer 1200 miles away. They were my "eyes" and I would tell them what to look for. I only want the opportunity of returning a similar favor for someone else.
Thank you all for your kind words of wisdom. Since last night I have been processing this situation over and over....much like many of you have on your own crafts. I know the 60's did not have the frequency of tail droop or separation problems as the 70's, but some indeed had some problems. I found an AS Service Bulletin (#146) on one of the forums here and printed it out. Makes perfect sense when it comes to "Shell to Chassis Separation." I'm thinking (not knowing) I may have other issues that may be way out of my family's budget. Of course, it will take my removing the bottom pan(s) for a more intimate inspection to know 100% for sure.
Let's say I pull the pans down. Exactly WHERE and WHAT am I looking for? Some mentioned cracks in the frame. Others mentioned rotted wood. Can't see the frame until I remove some covering. The floor in the rear compartment still seems strong with the exception of a small place (size of my palm) where the HW heater blew. I saw all of this at the initial and secondary inspections before buying, but all seemed acceptable to me at the time. What I did NOT know was the ripples or waves in the side panel above and around the wheel openings. How could a former body shop owner have underestimated the cause of those ugly things? I guess when you want an Airstream so badly, and you find one within your budget, and your kids are running up and down the interior's galley, and your wife loves the blue oven door...you just gotta spring for the dough!
Here's what I plan to do later today: Go home, put on my grubbies, take some photos of any and all related areas, post those, then let all of YOU (my dear friends) have at it. I am enamored by your kindness and your thoughtfulness. I will TRY to be patient, but even preachers have their limits, amen? I'll get back with you in a few hours. THANKS!
JB Baldridge
Old 01-12-2006, 01:24 PM   #9
Stefrobrts
Stefrobrts's Avatar
That sounds like a good idea. I am always amazed when someone posts pictures here, and people spot things I never would have noticed. I'll bet that will get you a lot of good feedback on your problem.
Stephanie
Old 01-12-2006, 02:27 PM   #10
BIGED52
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Nightmare
JB, Before you get too upset check this out! My 1967 Safari has some slight wavy areas on both sides behind and just above the wheel wells. I also noticed small splits in the exterior skins (less than 2") behind both wheel wells and missing rivets. My trailer only being 22' long got me to look harder at the wheel wells than elsewhere. I removed the roadside goucho, the flooring just behind the wheel well is warped upwards from below. I then looked under the trailer to discover the belly pan is bent upward just behind the wheel well. It appears that this damaged area may have been caused by tire blow-out some time in the past life of my trailer and that bent the outriggers on both sides of the coach. not hard to figure that the outriggers being forced upwards will give you missing rivets and wavy sides! I am in the process of repairing this at the current time. I want you to know that I too initially jumped to the frame seperation conclusion, but after further inspection have found the real problem to be much less of a challenge to repair. (And I am not a body man). So take another look at it and get a different prospective on what may be the real cause. You have a real find in that trailer and with a little TLC, will have many years of enjoyment out of it........P.S. Don't try to do it all at once! Make it a labor of love and it will pay you back ten fold.... Ed
BIGED52 is offline   Reply With Quote
Old 01-12-2006, 04:33 PM   #11
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Lets not get too carried away - - - - as mentioned send of some pictures - my first question is - do you have a place to work on it? Yes = 99% of problem solved (well maybe not that much - just trying to cheer you up a bit), then let us take a look at pictures - this is more labor than money to fix this - anything on your trailer is fixable so as mentioned above lets take it one step at a time - initially, I would crawl under there with a straight edge - you can feel the frame through the belly - as mentioned above I would highly doubt a cracked frame rail - maybe some welds have come loose on some cross members - or the out riggers - very easy fix - anyway, take your straight edge and move it along the main frame rail and you should be able to tell if the frame is bent - I'm sure you have done this on cars......push up and down along the belly and see if you can tell if anything is bent.
Seperation can/will happen on any of these trailers - my floor looked great, until I tore into it.....and I have frame seperation on my 58.....
I may bit a bit criptic - at work with phones ringing etc, but take some pictures lets take it one step at a time and figure out whats going on - then we will give you lots of opinions on how to fix it....
Ken
1958 Overlander
Ken J is online now   Reply With Quote
Old 01-12-2006, 06:29 PM   #12
sierrajb
sierrajb's Avatar
Fort Worth , Texas
Ripple Effect: Pictures & Inspection Results
Okay...here's what I've done.
1. I had the wife jump up and down in the bathroom while I watched for any separation between the bumper and shell. YES...about 1/2 inch. While I was at it, I took a look at the ripples on the sides while she continued her jumping. Saw no visible effects on the ripples.... The cause and cure of the dreaded ripples is probably NOT separation, but could be droop (caused by crack in frame?) or busted outriggers (which I have yet to learn what these are...hint, hint ).
2. Next, I put a floor jack under the exposed frame leading to my bumper. Jacked it up to see if it made any difference in the ripple effect....NONE.
3 Next, I took TEN pictures (max allowable) for your viewing pleasure.
a. The first two are of the ripples on the street side.
b. The next two are of the ripples (much less apparent) on the curb side.
c. The next two pictures are of the inside floor of the bathroom. Both are under the sink in the same area as the previously replaced HW Heater.
d. The next is a picture of the case of expandable foam used by the previous owner (to keep out field mice, etc.?).
e. The next picture is a crack in the ceiling panel located by the wall that divides the kitchen from the bedroom. Someone suggested this could be a result of unbalanced running gear rather than the result of droop.
f. The last two pictures definitely show prolonged trailering with unbalanced running gear. These are pieces of metal (in front of and behind the wheel well) that have worn through the skin. Wondering...is this part of the outrigging that some of you mentioned?
Well....take a good long look and let me know what you all think. Sorry about my initial response to this bleak discovery. My wife felt I was a bit over-dramatic and over the top. I told her that's really how I felt, and I would get plenty of sympathy from YOU. Can I get a witness?
Old 01-12-2006, 06:38 PM   #13
sierrajb
sierrajb's Avatar
Fort Worth , Texas
For BIGED52...
BIGED52...
You make some very interesting observations. You also helped me remember that the previous owner indeed had a blowout on his last trip home, thus the brand new tires. From reading your post it sounds like I MAY have the same situation as yours (hopefully!). Take a look at the last two photos and the ripples, then let me know if yours looks like this. Can you post pics and let me follow your progress of repair?
Old 01-12-2006, 07:04 PM   #14
Ken J
This is what I would do
1. What I mentioned above with straight edge
2. I think you have more rot than you think - its looks pretty rotted along that back edge - which is why you are seeing the "separation" at least this piece of flooring will need to be fixed.
3. To my way of thinking, the rot along that edge has caused things to loosen up a bit - if the PO used the trailer over rough roads - the body was flexing and therefore you see what you see......an unsupported frame is about as stiff as a rubberband.....
4. Those cutouts are caused by the outriggers rubbing on the skin - no biggy there....that could be imbalanced - lots of miles on the trailer - or loose skin that is flapping against that outrigger.
Ken J.
1958 Overlander
door hinge nightmare Mighty Gorg Doors & Locks 15 10-11-2006 08:04 PM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 06:31 PM
I have a Stream Dream !!
