Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 11-28-2007, 11:28 PM   #1
Judithheintz
Profile:  2008 28' International CCD
San Marcos , California
Smile International CCD Best Tow Vehicle...HELP!
My husband and I need advice on what tow vehicle is best for the CCD we ordered recently.
The dealer in Orange County recommended a 3/4 ton Suburban or Yukon XL.
We are finding either impossible to find(3/4 ton) either new or used. We are planning to travel full-time in 2008 across the US and don't want to make a mistake with the choice of tow vehicle.
Some GM dealers have told us that if the 1/2 ton has a 4:1 axle ratio, we will be okay. What do you experienced Intl CCD owners use as a tow vehicle?
Judie and Bob Heintz
Judithheintz is offline   Reply With Quote
Old 11-28-2007, 11:44 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us.
We tow Lucy (our '05 Safari 25 FB) with Olivia (our '05 Suburban 2500 4x4x4). We have driven the combo 25,000 miles. We have also towed Lucy with Matilda (our '04 Tahoe). The Tahoe is marginal, at best. The 3/4 ton Suburban gets the job done. You will probably not be happy pulling a 28' Airstream with a 1/2 ton Suburban. Even with the 4.10 rear end, the 1500 Suburban is not up to the task. The GM dealers who told you that a 1500 can handle it have probably never towed anything.
The 2500 Suburban has rear leaf springs; the 1500 doesn't.
The 2500 has a transmission cooler; the 1500 doesn't.
The 2500 has the 6.0 liter V-8; the 1500 has the 5.3.
The 2500 has an oil cooler; the 1500 doesn't.
The 2500 has truck brakes; the 1500 has car brakes.
The 2500 comes with Load Range E tires; the 1500 comes with Load Range C car tires.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 11-28-2007, 11:46 PM   #3
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by Judithheintz
We are planning to travel full-time in 2008 across the US and don't want to make a mistake with the choice of tow vehicle...
hi judith and welcome to the forums!
unless u need the seating for 6 a u-con or bourbon provides...
consider a 3/4 ton truck, crew cab (4 doors) with a diesel drivetrain.
then add a shell over the truck bed...
u will still have plenty of seating for people and pets
and the gear needed for camping is in a separate area, but still protected.
these trucks are plentiful and discounted now and no harder to drive than a behemoth suv.
a 1/2 with a 4.10 rear might work for an occasional vacation or weekend trip,
but you will reach the payload limit with the 1/2 going on full time adventures, and climbing will be sloooooooooooooooow.
the 1/2 ton will not result in any fuel cost savings while towing either.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 11-28-2007, 11:51 PM   #4
Harry W
Harry W's Avatar
Profile:  1978 31' Sovereign
Scottsdale , Arizona
Tow Vehicle
A 3/4 ton diesel powered pickup is the best choice. Whatever brand you like as long as it is a diesel. I am partial to Ford, having owned a 3/4 ton Super Duty Super Cab 8 foot bed for ten years. You will get better mileage and much better towing performance with the diesel. I towed with a '94 3/4 ton Suburban prior to the Ford, and I wouldn't go back for anything. I was towing an enclosed car trailer, and hills that were 40 mph in 2nd gear with the 'burb were 65 mph in 3rd with the diesel. Mileage was improved by 50-60%.
Good luck with your new adventures.
Harry W
Harry W
4CU Charter Member
Harry W is offline   Reply With Quote
Old 11-29-2007, 12:06 AM   #5
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
Since you will be fulltiming I'd suggest a 3/4 diesel. You'll get tons of performance. Going and stopping. A diesel pick up is no more difficult than a suburban to drive. Good fuel prices at Flying J and other truck stop R/V fuel centers. Also get higher mileage over a gas engine and go up hills at the same speed you gon on the flats.
If you were only going locally I think a suburban 3/4 would be ideal. I'm not saying anything against 3/4 Subs. I've had two of them and they are really good at towing but a diesel is great at towing.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 11-29-2007, 01:20 AM   #6
rangebowdrie
Profile:  1971 25' Caravanner
scappoose , Oregon
Even though i tow with a 3/4 ton suburban, i agree with the aforementioned respondents. many of the experenced drivers in these discussions try to follow the 75% rule,thusly,a 3/4 sub. with 4.10 gearing, and a 6.0lt. engine should reasonably expect to tow around 7500lbs.,give or take some.
rangebowdrie is offline   Reply With Quote
Old 11-29-2007, 01:28 AM   #7
Goin camping
Judith and Bob,
I forgot to welcome you to the forums. We're glad your here.
As you've found out you can ask any question you may have about any aspect of Airstreams and tow vehicles and we're more than willing to give you our opinions.
Since your currently in So Cal. I'm inviting you to join us the California Streamers for our rallies. No membership required. Just join in and have fun.
On the Portal page you'll see Calstreamers threads for rallies, notreallyarallyrallies and spons. Spon =spontanious rallies. We go somewhere about every month. Hope you'll join in on one.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Old 11-29-2007, 02:02 AM   #8
rangebowdrie
scappoose , Oregon
Even though i tow with a 3/4 ton sub. i agree with the aforementioned respondants. many of the experienced drivers ~follow the 75% rule, so a 3/4 ton sub. should reasonably tow a ~7500lbs., and the tow rating is based upon only two people and 200lbs. cargo. The 28ccd is a hefty bit of weight to tow. With the demise of the big-cubic inch,high torque gas engines, The diesel has taken over heavy load towing. Alas,...That I could buy, a diesel sub. My wants are few in number,but certain of desire.
Old 11-29-2007, 05:47 AM   #9
Rebee
Profile:  2007 30' Classic
Leonardtown , Maryland
Tow Vehicle
Everyone is correct and the vehicles described will perform well.
Some more food for thought, I pull a 30 ft classic, dry 8,000 lbs.
I prefer the Dodge trucks. I am presently using a 2007 RAM 2500 (3/4 ton)with 6.7 ltr Cummins diesel, I have the 3.73 rear axel ratio. It has plenty of pull power and is not as thirsty as the 4.10 when not towing. I also went to the short bed, this will make backing and manuvering less labor intensive.
Give some serious thought to your hitch. Many good ones on the market. I use the Hensley, some what pricey but a very good interface between tow vehicle and trailer.
Good luck on you search
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 11-29-2007, 08:31 AM   #10
jkcru
jkcru's Avatar
Profile:  1976 23' Safari
Escondido , California
I use a 3/4 ton 07 Burb and am very satisified, but would suggest the advice about a pickup may be more in line with your needs. Come over to our Rally and visit 29 Nov to 2 Dec at Guajome Regional Park Oceanside Ca. We would enjoy metting you and could answer most of your questions. the park is off RT 76 about 6 mi. east of Hwy. 5 El Camino Real Unit 12-014 WBCCI. Welcome aboard and hope to see you.
jkcru is offline   Reply With Quote
Old 11-29-2007, 09:53 AM   #11
starflyte1
starflyte1's Avatar
Bonita Springs , Florida
We have had both an 05 Suburban and an 05 Avalanche. Both were 2500 with the 8.1 gas engine and 4x4.
Yes, they are hard to find-I think I read that one in 10 is the 2500, 8.1. But we loved our Suburban and now the Avalanche. The Sub pulled a 28' AS, and now we have travelled 18,000 miles this year towing either a 23' AS or a 25' AS with the Avalanche, with no problems on two trips to the west coast. 06 was the last year to buy new either the Suburban or Avalanche with the 8.1.
We bought both thru cars.com. Both were sold by a Chevrolet dealer.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 11-29-2007, 01:19 PM   #12
Macfrodge
Macfrodge's Avatar
Profile:  2005 25' International CCD
Ottawa , Ontario
We pull our 25' ccd with a Ford F-150, extended cab.
Seems to do fine.
Macfrodge is offline   Reply With Quote
Old 11-29-2007, 03:35 PM   #13
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Welcome Judith and Bob
I am afraid I have to echo the above comments. No matter what brand you decide on 3/4 ton or above defineatly diesel power train 3:73 gears work good for me. No matter what U decide, a good wieght distrubution, Straight line hitch, will do the trick,U dont need a $3000.00 hitch either.People will say anything to sell U something. Remember "The only Stupid Question is THE ONE U DONT ASK" There is always someone here with yrs of experience with AS and Towing that will be more than glad to answer your Questions.
Hope we see Ya out there.
Roger
Mikethefixit is offline   Reply With Quote
Old 11-29-2007, 04:38 PM   #14
millvalleyca
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
Go with the 3/4 ton truck. We have the new 2008 Ford 250 with a diesel. GREAT truck! The tow command, integrated brake control and best of all the electric extended side mirrors. We had a 2007 GMC Yukon XL and found it wasn't enough to pull our 25' SS. I just didn't feel comfortable (a little nervous at times) pulling with it. It didn't have the "reserve power" the truck has.
Just remember...... a sales person will tell you anything you want to hear.
millvalleyca is offline   Reply With Quote
2003 International CCD Pahaska 2003 International CCD 5 10-27-2006 11:37 PM
2002 CCD International sandyb 2002 International 0 10-26-2006 02:09 PM
What do I need to tow a 28 International ccd? amathis50 Tow Vehicles 8 01-25-2005 09:14 PM
International 22' AS Tow Vehicle rmmm68 Airstream Motorhome Forums 7 11-02-2002 08:48 AM
International Tow Vehicle Hubba Our Community 18 10-31-2002 12:56 AM
