Old 04-13-2008, 05:48 PM   #1
1969 31' Sovereign
Amity , Pennsylvania
Interior painting
Hello all, I just picked up a 69 Sovereign 31 for $700 in fair/good shape... Everything OK, 1 broken window, furnace dosen't work. Form what I have read here I happened into a good deal. The inside is a bit dingy does anybody have a tip on paint to use on the vinyl interior panels?
Thanks, TED
preacher360 is offline   Reply With Quote
Old 04-13-2008, 06:09 PM   #2
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Silver City , New Mexico
I remember reading something posted by 2Air some time ago regarding painting the walls... said to make sure and get the vinyl off because it is not good surface for paint - wouldn't adhere well.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 04-13-2008, 07:30 PM   #3
Paint will stick to the interior "vinyl clad" metal.
But you must clean the walls very well.
Then you "MUST" sand into the vinyl with at least 100 to 120 grit sandpaper.
Scuffing won't do it, sanding is a must.
Then you use a high quality "primer."
Let the primer "out gas" for a couple of days.
Then, paint over the primer, using a high quality paint.
If you sand the vinyl with an 80 grit sand paper, you can actually use "Zolotone."
Our shop has used both of these methods, without any long term failure.
Old 04-14-2008, 06:40 AM   #4
1969 31' Sovereign
Thanks, from your replies I read some other threads I will sand and prime with Sherwin Williams and top coat with a slightly textured acrylic to approximate the orginal vinyl. The '69 should be livable by May
Interior painting question? JoshuaTonbo General Interior Topics 19 05-28-2016 08:24 PM
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
interior painting solitaire Upholstery, Blinds, Walls & Interior Finishes 14 11-01-2009 08:39 PM
painting interior argosy woodcarver General Interior Topics 3 01-07-2007 07:08 PM
Sanding / painting interior kamo Upholstery, Blinds, Walls & Interior Finishes 7 10-06-2006 10:28 PM
