Old 08-18-2006, 08:29 PM   #1
Havre , 37596 Hi-Line Loop
Cool Interested!
I am searching out info concerning vintage airstreams. I would like to know which is the largest 40's-60's model that can be pulled with a modern, small SUV (ex. nissan exterra, ford escape, hiunda santa fe). and can any be pulled with a 2000 pontiac boneville?
clmascara is offline   Reply With Quote
Old 08-18-2006, 08:35 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
depends on the tow rating for those vehicles of course. But I am guessing something under 25' with the proper tow set up would be most likely to work. Read some threads here on towing and such you will get the idea.
With something like the SUVs you mention, you might have a plane, as for the Pontiac, I would think its only suited to something on the order of a Bambi or Pacer...like 16-19'.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-18-2006, 08:58 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
To pull with a small sedan, you should stick with 19' or under. If the Bonnevile is front wheel drive, you need to be extremely careful. FWD's cannot tow very much or very well.
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-18-2006, 09:13 PM   #4
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Hello and welcome to the forums, clmascara! Towing and weights was a big concern for me as well when searching for my Airstream. Check this document (http://www.airstream.com/airstream/p.../weights-1.pdf) at the Airstream factory website. It lists weight specs for trailers back to 1954. I found that generally the older the trailer, the lighter. Consider this is dry weight only and doesn't account for the 1000 lbs. or so of batteries, generator, full LPG tanks, and your generalized stuff that you will need to carry. Also consider the wheelbase of your tow vehicle. The shorter the wheelbase, as in smaller SUVs, the less stability when towing. I found the Towing (Hitches, Braking & Vehicles) forum to be extremely helpful. Peruse and search the posts and you will find lots of good stuff. Good luck and be safe!
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Anyone interested in assisting on a floor replacement? Possibly more Peter Luger Repairing/Replacing Floor &/or Frame 5 03-24-2006 10:42 AM
for those interested in electric water heaters icedcacti Water Heaters, Filters & Pumps 0 01-05-2006 09:33 PM
Hitch set up question SafeHarbor Hitches, Couplers & Balls 33 11-20-2005 01:50 PM
interested in interviewing Bay Area airstreamers clloyd Our Community 0 09-30-2004 06:11 PM
Forum Rally's - Anyone interested? John Our Community 26 10-30-2002 10:27 AM
