Hello and welcome to the forums, clmascara! Towing and weights was a big concern for me as well when searching for my Airstream. Check this document (
http://www.airstream.com/airstream/p.../weights-1.pdf) at the Airstream factory website. It lists weight specs for trailers back to
1954. I found that generally the older the trailer, the lighter. Consider this is dry weight only and doesn't account for the 1000 lbs. or so of batteries, generator, full LPG tanks, and your generalized stuff that you will need to carry. Also consider the wheelbase of your tow vehicle. The shorter the wheelbase, as in smaller SUVs, the less stability when towing. I found the
Towing (Hitches, Braking & Vehicles) forum to be extremely helpful. Peruse and search the posts and you will find lots of good stuff. Good luck and be safe!
