Old 09-29-2009, 08:24 AM   #1
TAE
TAE's Avatar
1977 24' Argosy 24
Clearwater , Florida
Inspector in Dighton, MA?
Hello, I am new Airstream owner.Brand new to this site. I have to learn everything!!! I am looking for HELP!! I have bought a 1977 Argosy 24 it is in Mass. and I am in Florida. It needs work. Any one out there with a lead in the area of Dighton MA. of a trustworthy person to take a look at it? Thanks so much TAE
TAE is offline   Reply With Quote
Old 10-01-2009, 10:27 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello TAE - welcome to the forums! I've moved your post to a standalone thread.
Has the '77 you're looking at received any regular usage? It's hard for them to vouch for the air conditioner unless they've actually had it at a campground 30A outlet and operating. A fridge replacement can be one of the most expensive single maintenance issues. An original furnace must be replaced as a simple safety issue. HW heater probably isn't doing real well. Original copper pipes are subject to irreversible frost damage unless the unit was very well maintained.
And finally, like any 'Top 10' list, the most common and sometimes largest issue is, "They all leak." That's just impossible to avoid. It's hard to imagine how any inspection could have found two of the four floor rot problems I had. Hint: look very carefully around the battery compartment -- visualize the floor under the wardrobe in front of the Univolt.
Good luck in your quest.
5 meter Langford Nahanni
Inspector in Albuquerque?? Woody.303 Buyer Guidelines 27 04-16-2009 07:37 AM
Inspector in Louisiana? erichatten Buyer Guidelines 2 11-21-2008 05:08 PM
Need inspector in CT ctdadof3g Buyer Guidelines 1 10-17-2008 01:42 PM
I Need An Inspector in NJ.....Anyone? MuthaMustard Buyer Guidelines 2 05-26-2008 10:47 PM
Need a PA inspector wannaroam Our Community 2 11-03-2006 05:56 PM
