Old 08-06-2013, 09:30 PM   #43
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Hmmmm ... I may try to affix a removable aluminum table as a rock guard ......
.... pursue ease and grace ....
awryawry is offline   Reply With Quote
Old 08-11-2013, 03:36 PM   #44
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Solar panel "trim" ...
... and more:
Stand-off frame is all riveted on, with RBBB's (rubber baby buggy bumpers) affixed to the "belly band, or whatever you call it. I utilized the existing rubber bungee hold-downs by attaching the claw-catches to the bottom of my frame.
As the conductors for my panel have quick-disconnects, I believe I'll just plug 'em in when desired, and unplug 'em for rollin' down the road for now.
Paul, the PO of "Solid Comfort", put his first dent ever into the starboard bow, on what proved to be his last 'streamin' haul ever. On his way up to Cortez, he had an unfortunate close encounter with a ubiquitous orange construction barrel.
I cut an 8" x 8" access hole through the inner skin below the couch arm, and reached in there with a variety of improvised tools to punch the dent out. It ain't purty, but it's better than it was! I patched the inside with a plant-on aluminum cover.
Shake-down cruise in two weeks -- all of 12 miles up to Junction Creek C.G.
My main man Tony's installing a brake controller and air-bag suspension in the Sex Machine this week ...
Anybody else feeling a hint of Fall in the air?
wryawry
Name:	AS PV framed.jpg
ID:	192937   Click image for larger version
Name:	AS PV propped.jpg
Name:	Paul's last dent.jpg
ID:	192939   Click image for larger version
Name:	Paul's dent punched out.jpg
Old 08-11-2013, 09:38 PM   #45
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Howdy. Here's another task: removed the heavy plastic cover over the carpet in the "garage" -- rear storage compartment. Really, Airstream? with the chronic issues from water infiltrating over the bumper and into the sub-floor, the design is to simply run the carpet over the whole shitteree, then cover it with plastic to ensure that any moisture -- no, water -- just sits on the plywood sub-floor? Seems to me that Airstream "engineers" could use a refresher course in the "Seven P's" ...
Just ask if you don't know them,
wryawry
Old 08-12-2013, 09:21 AM   #46
awryawry's Avatar
2000 27' Safari
Durango , Colorado
It's refreshing to know that 'streamers know the 'Seven P's'!
Old 08-13-2013, 03:11 PM   #47
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Of course we know I hear it over my right shoulder on a regular basis and I do love that woman cause she keeps me and that m-law thing in check! You are doing an awesome job I hope you enjoy the streamin as much!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-13-2013, 03:13 PM   #48
1966 17' Caravel
Obtw when are you gonna buy a or adopt a vintage to rebirth! ( found that the rebirth is for the pain not the joy of the renovation)
Old 08-14-2013, 08:53 PM   #49
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Okey-dokey ....
... just a small observation: righty-tighty; lefty-loosey.
Why should AS window knobs be counter-intuitive?
Bewildered,
wryawry
Old 08-18-2013, 09:40 PM   #50
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Progress and questions.
Howdy, all you Silverstreamists,
I got the PV wired. After much consideration, I elected to mount the charge controller within the battery box that Paul the PO, had installed on the tongue assembly behind the LP tanks. The controller fit nicely over the battery, and as it is solid state (for Solid Comfort!), there is no worry of sparks potentially igniting the battery's outgassing.
For travel we can easily unplug the panel leads and coil them within the battery box. Couple a' pics below.
I've got gas struts on order to hold the panel up when we're docked or anchored or whatever you wacky, crazy, loony 'streamers call it when you're parked.
I ripped-out the funky carpet in the "garage" hatch. There's a nasty lateral seam in the plywood subfloor about six inches in -- stitched together with broad-crown staples (--? -- !) I'm gonna glass that seam and epoxy-coat the plywood, then I'll just lay-in rubber matting for the garage floor for all the shovels and rakes and implements of destruction that came piled-up in that compartment. Marine-grade plywood? NAH!
Ever noticed how 14-year-old door hardware becomes a bit recalcitrant? My loving wife did, and sure enough, she locked the door. Well, no need to wonder where Mr. Wonderful had left the keys ... I remembered that the rear egress window frame had been "popped" a bit, as one of the latches had been broken sometime in the murky past. I was able to pull the window out enough to insert a proverbial six-foot-pole, and trip the remaining latch. The Missus got to crawl in and familiarize herself with the door hardware.
FYI, she was wearing a little sundress ..... one might say that Airstreams ARE a silver lining!
Questions:
1. Why is there a 3" round hole bored through the bow, with a typically-poorly-caulked cover-plate screwed on, and a 2' section of 1-1/2" corrugated radiator hose laying on the floor forward of the couch? Is this so that if you can't take the necessary repairs anymore you can affix and exhaust hose from your TV and end all the trials and tribulations? There's a thoughtful touch, AS!
2. Any unique suggestions for a screen protector for the inside of the screen door to protect it from rampaging dog claws?
3. Anybody wanna buy some angrily ripped-out, stanky, shredded carpet?
Thursday, we launch,
wryawry
Name:	AS PV wired.jpg
ID:	193569   Click image for larger version
Name:	AS PV controller in box.jpg
Name:	AS PV chg cont.jpg
Old 08-19-2013, 07:58 AM   #51
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Bump.
« Introduction | Top | n00b! »
Dometic Comfort Control Center Codes fmrcaptevil Furnaces, Heaters, Fireplaces & Air Conditioning 41 10-21-2012 06:56 AM
NEWBIE: Hope to purchase Used Sport or Bambi room202d Member Introductions 2 01-11-2012 10:50 PM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
Off to bring home a new baby (I hope) meredith Our Community 16 07-13-2011 09:11 PM
Solid Trac tires 63air Tires 2 06-02-2011 09:18 PM
