08-24-2012, 08:49 PM
#21
Holly Lake Ranch
Originally Posted by Ramble On
Interesting. Thanks for muddin'ing the water even more.I will look at the towing and payload specs.
Where do you store your trailer and what is the cost?
Am storing up in Princeton, covered but not completely enclosed for $75 a month. Comparable storage, if you can find a slot, in Rockwall is $150 to $200.
its kind of far away and if i had an AS that I had to do a lot of work on, I would want it closer, but DW wants her AS under cover, so that was the best deal I could find. Its called A Great Storage Place for Boats and RVs, between Lucas and Princeton.... wouldn't be a bad drive for you because you could go up 205 and catch 78 then across 380 and down the FM road to Princeton.
about 22 miles from Rowlett.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
08-24-2012, 09:05 PM
#22
2012 25' Flying Cloud
Battle Lake
08-24-2012, 09:12 PM
#23
2004 28' International CCD
rockwall
Damn, this is to much information for my pea sized brain.
08-24-2012, 09:30 PM
#24
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Hi from central Texas and welcome to the forums! I have read and heard a lot of wonderful things about the F150 Eco-Boost. I have a good friend that has one. He traded his F-250 for it. I'm of the thought that you don't need a monster truck to tow an Airstream. I have a 29' 1972 Ambassador that I have towed with a 2002 Toyota Sequoia from Texas to Colorado and Utah twice now and have had no issues with my set up. I'm comfortable with it. If you are concerned about mountain towing, you should be concerned with the brakes on your trailer as much as, if not more than, the tow vehicle you are towing with. Proper set up, service etc. There are a lot of opinions out there as to what you need to tow an Airstream with. Get what feels right and safe for you.
Enjoy your Airstream and have fun! Hope to see you on the road or at a rally soon.
Lance
08-24-2012, 09:47 PM
#25
rockwall
It is my understanding that the early models of Airstreams were considerably lighter in weight than what I will be towing. What is the GVWR of a 1972 Ambassador?
My trailer is 7300# GVWR.
08-24-2012, 10:04 PM
#26
2005 31' Classic
2005 31' Classic
Douglass
I agree, buy what fits you. However, here was my experience when I was in your situation. Bought my 25' 5K lb Airstream new in 2001. Got with my Airstream salesman and my local Dodge dealer and told them to pick me a truck that would tow the trailer well in all situations. They both recommended I needed a 2001 Dodge Ram gasoline 1/2 ton. Bought the 1/2 ton Dodge Ram and took off from East Texas headed for Yelllowstone. Got 5 miles per gallon. Got blown all over the road by 18 wheelers. Had a hard time climbing some of the Rocky Mountains I encountered, and had a hard time controlling it down the otherside. Experienced a lot of "white knucle" driving. Felt like trailer was pushing truck downhill. However, I put up with all this because surely this was just the way it was, both sales people recommended this combination. In the fall of 2002 I went to Branson Missouri pulling the AS. As you probably know, the hills around there are not as steep as the Rockies but they are long. When we hooked up to the AS to leave, the 1/2 ton Ram would not pull it out of the RV camp spot. Had to stay another couple of days to get the local Dodge dealer to repair the tranny. Drove straight home from Branson to East Texas after the repair, traded that 1/2 ton for a brand new 2003 3/4 ton Diesel Dodge Ram, and have enjoyed traveling with an Airstream in total comfort, control, and efficiency ever since. The way Airstream travel should be. 17 MPG towing, 21 not towing. No wind turbulence by bigger vehicles, Plenty of torque to climb any mountain I have encounter all over the US and Souther Canada. No pushing downhill. Cruise at 70 on interstates with trailer in tow. 3/4 ton Diesel Ram now has 133K on it and is still going strong on long Airstream trips. Not even broke in good yet. Love it! Especially with the AS hooked up and rolling around the country or making short trips. Thats my 2 bits worth!
James Rudd
2001 25' Safari
2003 Dodge 2500
08-24-2012, 10:15 PM
#27
Always learning
1972 29' Ambassador
Central
My Ambassador has a GVWR of 7,100# Very close to what you have. I don't get too close to the trailer's max GVWR.
Lance
08-24-2012, 10:37 PM
#28
rockwall
What does it cost to put disc brakes on an Airstream?
08-24-2012, 11:29 PM
#29
Alamo Heights
About $1400 in parts, and lord-knows-what in labor.
— David
08-25-2012, 12:24 PM
#30
rockwall
Just finished picking up our trailer and getting it stored. Man do I have alot of questions.
It has a draw tite WDH installed that I did not hook up because I didn't know how. I assume it is adjustable to match the tow vehicle. I need to learn how to do this. Any suggestions?
08-25-2012, 01:17 PM
#31
Holly Lake Ranch
AIR Forums, YouTube and Google are your friends
congrats on getting the AS back to Rockwall.
As to learning all this stuff, you are absolutely in the right place. Used the search function to find answers to just about anything you want to know.... and if you don't find it, ask.
PO should have shown you how to hook up the WD hitch... mine did. It certainly will make a difference when towing... so don't judge this trip home as the norm if you didn't have either WD or sway control.
Dana
Dana and Olga
2006 Safari 23
08-25-2012, 03:34 PM
#32
Holly Lake Ranch
Photos of your new toy?
Dana and Olga
2006 Safari 23
08-25-2012, 06:58 PM
#33
rockwall
I will try to post photos tomorrow. Went truck shopping today and will probably pull the trigger Monday. New trucks are expensive. I will exceed my budget. Oh well.
08-25-2012, 07:19 PM
#34
Tenkara Fly Angler
1975 31' Sovereign
Vernon
I have done that before, not with an Airstream, but a full load of grass sod on a Dodge 1500 and 18 ft trailer. Had to stop at the bottom and relieve myself. Bought my first diesel after that. Now once I get over my fear of heights...
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
08-25-2012, 08:26 PM
#35
rockwall
Dana
Wasn't to bad, towing with and older f350. I'm sure with the proper setup, towing will be just fine. Experienced no sway with trucks passing me, only a little bucking on rough roads.
08-25-2012, 08:28 PM
#36
Battle Lake
If you guys had replaced the passenger car tires on your Dodge 1/2 tons with truck tires it would have been at least as stable as the the larger truck. Adding a Hensey hitch would eliminate sway completely.
doug k
08-25-2012, 08:31 PM
#37
Holly Lake Ranch
Our PO said he drove all the way from Midlothian to Banff and back without using sway control and said the trailer tracked perfectly all the way. Something to be said for the aerodynamics.
Once i got used the feeling of a little push as semi's pass on the interstate, I've not encountered anything that even faintly resembles sway.
Dana and Olga
2006 Safari 23
08-25-2012, 09:39 PM
#38
rockwall
Older trucks ain't up to the standards of today's current crop of 1/2 ton ton trucks. Ford and other manufactures have expanded the capabilities of the 1/2 ton. My old 2002 dodge ram can"t tow sh*t.
08-25-2012, 10:01 PM
#39
Tenkara Fly Angler
1975 31' Sovereign
Vernon
doug k
Did that. Would never pull up or go down a 7-10% grade with any fully loaded trailer with any 150,1500 or what ever gas engine again when I can do it with a diesel that was built to haul.
Biased toward fully packaged diesels, yes.
1975 Sovereign
"The Silver Bullet"
WBCCI #8578
08-25-2012, 10:22 PM
#40
rockwall
OK, what is the difference between LT and P tires? Should I get LT tires?
