Old 08-24-2012, 11:29 PM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by Ramble On View Post
What does it cost to put disc brakes on an Airstream?
About $1400 in parts, and lord-knows-what in labor.
David
Old 08-25-2012, 12:24 PM   #30
Ramble On's Avatar
2004 28' International CCD
rockwall , Texas
Just finished picking up our trailer and getting it stored. Man do I have alot of questions.
It has a draw tite WDH installed that I did not hook up because I didn't know how. I assume it is adjustable to match the tow vehicle. I need to learn how to do this. Any suggestions?
Ramble On is offline   Reply With Quote
Old 08-25-2012, 01:17 PM   #31
Goal15's Avatar
Holly Lake Ranch , Texas
AIR Forums, YouTube and Google are your friends
congrats on getting the AS back to Rockwall.
As to learning all this stuff, you are absolutely in the right place. Used the search function to find answers to just about anything you want to know.... and if you don't find it, ask.
PO should have shown you how to hook up the WD hitch... mine did. It certainly will make a difference when towing... so don't judge this trip home as the norm if you didn't have either WD or sway control.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-25-2012, 03:34 PM   #32
Goal15's Avatar
Photos of your new toy?
Dana and Olga
2006 Safari 23
Old 08-25-2012, 06:58 PM   #33
Ramble On's Avatar
rockwall , Texas
I will try to post photos tomorrow. Went truck shopping today and will probably pull the trigger Monday. New trucks are expensive. I will exceed my budget. Oh well.
Old 08-25-2012, 07:19 PM   #34
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Originally Posted by jrudd1968 View Post
I agree, buy what fits you. However, here was my experience when I was in your situation. Bought my 25' 5K lb Airstream new in 2001. Got with my Airstream salesman and my local Dodge dealer and told them to pick me a truck that would tow the trailer well in all situations. They both recommended I needed a 2001 Dodge Ram gasoline 1/2 ton. Bought the 1/2 ton Dodge Ram and took off from East Texas headed for Yelllowstone. Got 5 miles per gallon. Got blown all over the road by 18 wheelers. Had a hard time climbing some of the Rocky Mountains I encountered, and had a hard time controlling it down the otherside. Experienced a lot of "white knucle" driving. Felt like trailer was pushing truck downhill. However, I put up with all this because surely this was just the way it was, both sales people recommended this combination. In the fall of 2002 I went to Branson Missouri pulling the AS. As you probably know, the hills around there are not as steep as the Rockies but they are long. When we hooked up to the AS to leave, the 1/2 ton Ram would not pull it out of the RV camp spot. Had to stay another couple of days to get the local Dodge dealer to repair the tranny. Drove straight home from Branson to East Texas after the repair, traded that 1/2 ton for a brand new 2003 3/4 ton Diesel Dodge Ram, and have enjoyed traveling with an Airstream in total comfort, control, and efficiency ever since. The way Airstream travel should be. 17 MPG towing, 21 not towing. No wind turbulence by bigger vehicles, Plenty of torque to climb any mountain I have encounter all over the US and Souther Canada. No pushing downhill. Cruise at 70 on interstates with trailer in tow. 3/4 ton Diesel Ram now has 133K on it and is still going strong on long Airstream trips. Not even broke in good yet. Love it! Especially with the AS hooked up and rolling around the country or making short trips. Thats my 2 bits worth!
I have done that before, not with an Airstream, but a full load of grass sod on a Dodge 1500 and 18 ft trailer. Had to stop at the bottom and relieve myself. Bought my first diesel after that. Now once I get over my fear of heights...
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 08-25-2012, 08:26 PM   #35
Ramble On's Avatar
rockwall , Texas
Dana
Wasn't to bad, towing with and older f350. I'm sure with the proper setup, towing will be just fine. Experienced no sway with trucks passing me, only a little bucking on rough roads.
Old 08-25-2012, 08:28 PM   #36
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If you guys had replaced the passenger car tires on your Dodge 1/2 tons with truck tires it would have been at least as stable as the the larger truck. Adding a Hensey hitch would eliminate sway completely.
doug k
Old 08-25-2012, 08:31 PM   #37
Goal15's Avatar
Our PO said he drove all the way from Midlothian to Banff and back without using sway control and said the trailer tracked perfectly all the way. Something to be said for the aerodynamics.
Once i got used the feeling of a little push as semi's pass on the interstate, I've not encountered anything that even faintly resembles sway.
Dana and Olga
2006 Safari 23
Old 08-25-2012, 09:39 PM   #38
Ramble On's Avatar
rockwall , Texas
Older trucks ain't up to the standards of today's current crop of 1/2 ton ton trucks. Ford and other manufactures have expanded the capabilities of the 1/2 ton. My old 2002 dodge ram can"t tow sh*t.
Old 08-25-2012, 10:01 PM   #39
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
doug k
Did that. Would never pull up or go down a 7-10% grade with any fully loaded trailer with any 150,1500 or what ever gas engine again when I can do it with a diesel that was built to haul.
Biased toward fully packaged diesels, yes.
1975 Sovereign
"The Silver Bullet"
WBCCI #8578
Old 08-25-2012, 10:22 PM   #40
Ramble On's Avatar
rockwall , Texas
OK, what is the difference between LT and P tires? Should I get LT tires?
Old 08-25-2012, 11:20 PM   #41
dkottum's Avatar
As for towing your Airstream, the greatest difference is stability. The stiffer sidewall of the LT tire does not allow the side-to-side movement of passenger tires. Dramatic difference on our light 1/2 ton truck; I see no worthwhile advantage to pull our Airstream with a larger truck, but perceived need varies.
doug k
Old 08-26-2012, 09:35 AM   #42
Goal15's Avatar
I ended up buying a basic 2011 Toyota Tundra 5.7L with tow package and shifter on the column, guess it just depends on the level of luxury you want. We recently added OEM tow mirrors and I added a truck bed bike rack, but other than that have been very happy with the truck and am about to hit the 20K mark.
Have discovered that the shifter on the column actually gives you extra space in the frontseat floor for stuff you really need to have up there when traveling... so that was a bonus..... of course I also get the "I didn't realize the still put automatic transmission shifters on the column anymore" on occasion.
Dana and Olga
2006 Safari 23
