06-04-2008, 05:48 PM
pagosa springs
How Does This stack up to an 21-22 ft. AS?
Check the pics here:
Keygarv Travel Trailers: Photo Gallery
It is 600 lbs heavier, 3 inches taller, 1/2 ft narrower, 2 inches wider for the bed. It extends out with the queen to 25' total. Same price as a used 92' AS 21'. Enclosed bottom so it reduces drag. 50 gal fresh water, 40 black, 40 grey, 60 lpg., outside grill, bunk beds in front, flat screen TV. It's an 07, but what about resale with it vs. the AS? Outback has a transferable warranty.
06-04-2008, 07:27 PM
1972 Argosy 20
1977 Argosy Minuet 6.0 Metre
Fort Collins
FWIW, the 21' Airstream will probably be worth about as much in five years as it is worth now. Hard to estimate but I'd guess this Outback model will depreciate rapidly.
06-04-2008, 07:30 PM
1955 22' Safari
Great Lake State
What will it be worth 50 years from now............
06-04-2008, 07:39 PM
1968 17' Caravel
Battle Ground
My Airstream is older than I am, and it's going up in value. Too bad I can't say the same for me
Stephanie
06-04-2008, 08:27 PM
1986 31' Sovereign
Miami
It's a plastic box held together by staples. Essentially a disposable RV that in 10 years will be valueless.
An Airstream, as noted, will likely be worth about what you paid for it in 10 years.
Not to mention the smile factor. I am genuinely fond of my Sovereign.
Can't imagine getting attached to an SOB.
mike
06-04-2008, 08:46 PM
1986 25' Sovereign
Southern Middle
Come on Steph, I've seen a few pictures of you and you're priceless.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
06-04-2008, 09:23 PM
pagosa springs
Thanks, I actually took a look tonight at the Outback and for a year old, it had alot of problems and didn't seem that well built. Think I will stick with a AS. Just have to make up my mind as to a 19' vs. a 21-22' AS.
06-04-2008, 09:59 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
I don't understand the question.. ... ... .......
06-04-2008, 10:20 PM
1968 17' Caravel
Battle Ground
I try to be handy, you know what Red Green says about that
Stephanie
