Old 06-04-2008, 05:48 PM   #1
pagosa springs , Colorado
How Does This stack up to an 21-22 ft. AS?
Check the pics here:
Keygarv Travel Trailers: Photo Gallery
It is 600 lbs heavier, 3 inches taller, 1/2 ft narrower, 2 inches wider for the bed. It extends out with the queen to 25' total. Same price as a used 92' AS 21'. Enclosed bottom so it reduces drag. 50 gal fresh water, 40 black, 40 grey, 60 lpg., outside grill, bunk beds in front, flat screen TV. It's an 07, but what about resale with it vs. the AS? Outback has a transferable warranty.
gc24 is offline   Reply With Quote
Old 06-04-2008, 07:27 PM   #2
1972 Argosy 20
1977 Argosy Minuet 6.0 Metre
1979 30' Argosy
Grand Junction , Colorado
FWIW, the 21' Airstream will probably be worth about as much in five years as it is worth now. Hard to estimate but I'd guess this Outback model will depreciate rapidly.
kenny2 is offline   Reply With Quote
Old 06-04-2008, 07:30 PM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
What will it be worth 50 years from now............
toastie is offline   Reply With Quote
Old 06-04-2008, 07:39 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My Airstream is older than I am, and it's going up in value. Too bad I can't say the same for me
Stephanie
Old 06-04-2008, 08:27 PM   #5
1986 31' Sovereign
Miami , Florida
It's a plastic box held together by staples. Essentially a disposable RV that in 10 years will be valueless.
An Airstream, as noted, will likely be worth about what you paid for it in 10 years.
Not to mention the smile factor. I am genuinely fond of my Sovereign.
Can't imagine getting attached to an SOB.
mike
Old 06-04-2008, 08:46 PM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Come on Steph, I've seen a few pictures of you and you're priceless.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-04-2008, 09:23 PM   #7
Thanks, I actually took a look tonight at the Outback and for a year old, it had alot of problems and didn't seem that well built. Think I will stick with a AS. Just have to make up my mind as to a 19' vs. a 21-22' AS.
Old 06-04-2008, 09:59 PM   #8
2004 25' Safari
South West , USA
I don't understand the question..... ..........
-Ed
RivetED is offline   Reply With Quote
Old 06-04-2008, 10:20 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I try to be handy, you know what Red Green says about that
Stephanie
Water Coming in the Reefer Stack PoconoAir Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 06-22-2007 11:44 AM
Installing soil stack covers Will Ackerman Roof Vents, Skylights & Fans 4 09-11-2004 06:20 PM
Vent stack covers silverhawk Roof Vents, Skylights & Fans 3 02-03-2004 04:35 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
