03-24-2010, 03:10 PM
1975 27' Overlander
bay st louis
, Mississippi
How do you empty septic holding tank?
Hello,
Just got a 1975 airstream,
I not sure how to empty septic, should i pull main holding tank line out or push it in? If it still dosn't empty, as it is backed up water in shower, your advise would be appreciated very much,
Thank you,
the rookie
03-24-2010, 03:23 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
On a 75 you have 2 valves 1 for gray water,1 for black water,they are both located in the trunk ,black handle is in the left side of tank,pull up to drain,I always drain black first,then move over to right valve,pull it up,that should wash the black out.After draining push both valves back down. Dave
03-24-2010, 04:21 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
The valve maker 'main' should be the black tank, and the other valve, usually marked 'auxiliary' is the gray. The black tank holds water and waste from the toilet. The gray tank holds waste water from the sinks and shower. The water backed up in your shower is from the gray tank.
You must attach a sewer drain hose to you dump outlet prior to pulling either of those valves. The other end of the drain hose to a proper sewer dump.
Whatever you do, don't pull either of those valves until you are properly hooked-up.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-24-2010, 04:29 PM
2000 31' Land Yacht
Central
If you haven't done it before make sure you have the end into the sewer secured, rock, foot or even sewer pipe cover, hard to believe how much the pipe moves when it gets full force black water moving through it.
03-24-2010, 04:39 PM
1975 27' Overlander
bay st louis
, Mississippi
Brian
Thankyou Dave and Brian - i have it hooked up but have not pulled the left grey aux handle yet - should be good to go now! Take Good Care
03-24-2010, 05:15 PM
santa maria
Any one know what the pipe size of the dump outlet is?
