Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 02-12-2007, 12:50 PM   #1
mabuofh
Profile:  Houston , Texas
Houston... We have a problem!
Hello all. We are new to this site and any help would be great!
1970 Airstream Caravel
Problem: When water in kitchen or bathroom is on, water backs up into bathroom floor.
When you remove the gray water cap (outside), all water (toilet and sink) comes out regardless if valve is open or closed. Bathroom floor drains as well.
Any suggestions welcomed.
mabuofh is offline   Reply With Quote
Old 02-12-2007, 12:54 PM   #2
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
You do not have what is called a "gray water" or now called "wash water" holding tank. water from the sinks and shower goes directly to the drain line. The valve is for the toilet holding tank only. The second holding tank was not installed until the mid 1970's.
Hope this helps.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 02-12-2007, 12:54 PM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
That year (and other older ones) does not have a grey tank, so all grey water will run onto the ground if the cap is off. There is no valve for the grey. Most of us use a blue portable tank to contain the grey water. The other expensive option is to install a grey tank in the trailer - a lot of work!
Dave
Fyrzowt is offline   Reply With Quote
Old 02-12-2007, 12:57 PM   #4
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Working as designed.
There is no grey water tank on that model. (the factory didn't start installing them until 1974). The grey water drain lines simply terminate in the sewer line, below the level of the black tank valve. Only the toilet empties into the black tank; with the valve closed, that water should be contained, but grey water will just run out onto the ground. If the cap is on, there's no place for it to go, and it will back up into the shower.
beware of this: the black tank sits on the floor; anything accumulated in there will empty to the shower pan, if that valve is open, and the external cap is in place. Some people might tell you that you can let the grey water back-fill into the black tank by doing this; but that only works if the tank is mounted below the floor, and not all of them are.
Back in 1969, they didn't care about soapy water being dumped on the ground, but now, most places do. You either need to be connected to a sewer, like at a "full-hookup" site, or use an auxilliary external tank, often referred to as a "blue-boy" to collect this waste water, and wheel it over to a dump when its full.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-12-2007, 01:05 PM   #5
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Do you have a functioning black tank valve. If it is not working you can buy a kit to rebuild it. Then use that dump the black tank at appropriate places and the wash water will just run on the ground or into a blue boy. Get one with four wheels on the ground, they get real heavy fast.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 02-12-2007, 02:04 PM   #6
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
With some determination you can rig some PVC pipe to act as a small gray-water tank to accept minor amounts of water ... My '73 bathtub wants to function as a gray tank when I forget, guess it's a whole lot better than the floor...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 06:40 AM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 10:24 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
