Old 04-14-2007, 09:00 AM   #1
1972 31' Sovereign
seattle , Washington
hooked on a 1972 thirty-one footer
I have owned my trailer for about a year and decided to do a bit of remodeling. After tearing out the front couch and kitchen cabinets I found rot in my floor around the front window rolling towards the door. Does anyone have any suggestions how to remove and the bad subfloor and replace it. Or am I in for a larger than anticipated project?
Thanks Peter
pipet is offline   Reply With Quote
Old 04-14-2007, 09:20 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi Peter...welcome to the forums and Vintage trailer ownership I had rot under the front windows on my 75 and near the door. I replaced the entire front section of plywood. I did in by cutting a sheet in half on a bevel, then used a backing plate under the joint. I covered the joint in glue and screwed it about 4" on center. The reason I cut the plywood in half was to make it easier to get back in under the C-channel at the front. You are probably going to need to pull the belly pan and banana wraps too and check your outriggers and frame for rust. Good news is that the outriggers are still available from an Airstream Dealer and they aren't horribly expensive. Or you can fabricate them out of 18 gauge steel.
Aaron
WBCCI #XXXX AIR #2495
Old 04-14-2007, 01:29 PM   #3
1973 31' Sovereign
Portland , Oregon
Images: 22
Peter,
It is possible to replace pieces of the floor is you use plywood splines under the edges with glue and screws. Whether or not that makes sense depends on how extensive the damage is. Also you can examine the condition of the frame under the bad part of the floor it you cut out the bad places first. If things look OK you you might be able to save yourself the trouble of opening up the bottom.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 04-14-2007, 01:33 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Thanks Peter
Hey, and wecome!
Check out the reqpir we did to a 76 31'er
New to the French
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
59 Traveler bkpine 1959 Traveler 8 11-11-2002 10:31 PM
shag me andreaszabo 1974 - 1979 Sovereign 7 10-28-2002 05:24 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
1972 Tradewind plentycrafty Our Community 2 09-20-2002 08:50 PM
