Thanks for the reply, David! The new axles, breaks, bearings, and shocks are really going to make a difference for you - I changed the single axle on my Casita to a "high-rise" axle, added shocks, and upsized the wheels from 14" to 15" and it was a whole new beast!
My drain line upgrade/fix would have been completed today had I not grabbed 1-1/2" pvc instead of 2"...measure twice, buy once or something like that, right?
We were able to have another piece of the frame fixed today by the welder (a crack appeared - or went unnoticed - by one of the axles), patched a 2'x1' spot on the roof where a previous antenna was installed. It looked like a shotgun had peppered the outer skin with holes, but it's all sealed now and rain-tested! The welder helped me get the new 1/2" hex bolts through the frame and rear C-channel too, so hopefully our separation is solved too. Good day overall.
Best of luck to you on the Overlander!
