Old 02-02-2008, 05:36 PM   #1
1963 19' Globetrotter
Scotts Valley , California
I purchased a 1963 Globtrotter. I found a axle that was removed from a 2005 Bambi with tires and alloy stock rims. Will it fit my trailer? Is the load ratting correct? I have yet to move my trailer to my home so I can not measure. Mine has split rims so I thought this was a first good move. The axel is going for $275 & tires for $333 Should I be thinking this far ahead before I start restoration work? Thanks for any suggestions.
Wild Horse is offline   Reply With Quote
Old 02-02-2008, 06:36 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You really need to measure it. Why was the axle removed from the Bambi?
Old 02-02-2008, 06:59 PM   #3
The frame width on your trailer is 57 7/8 inches.
The 2006 is wider than that.
The mounting brackets cannot be moved without damaging the rubber rods, plus the overall width of the newer axle is much to wide for your 63.
Sorry.
The largest "Vintage"Airstream parts headquarters on the planet.
Old 02-02-2008, 07:31 PM   #4
The axle was removed because the owner built a custom motor home useing the Bambi for the hull. He put it on a new van. Boy was it cool looking!
Old 02-03-2008, 06:02 AM   #5
Baltimore , Maryland
can you post some pictures of that? I would love to see it.
What's This?? '62 Globetrotter Bradjun1 1960 - 1964 Globetrotter 4 08-22-2006 08:41 PM
help - 64 globetrotter bomack Member Introductions 5 06-05-2006 05:23 PM
65 globetrotter from nj hdnmcky Member Introductions 2 05-03-2006 04:36 AM
Just got our first AS...'65 Globetrotter! grnthumbguy 1965 - 1969 Globetrotter 4 09-08-2005 11:22 AM
'63 Globetrotter Mark Wiltrakis 1960 - 1964 Globetrotter 1 07-11-2005 12:22 AM
