Old 01-24-2006, 05:38 PM   #1
1968 30' Sovereign
Chico , California
Question Help! I need advice on fixing a big dent.
Hello, fellow airstreamers: I recently acquired a 1968 Land Yaght Sovereign in very good condition. The body was perfectly straight until last week when a well drilling company doing work on a water system nearby had a piece of equipment break, sending a large piece of flying metal into the top, front curve of my trailer! The dent is about 2 feet across, centered on a longitudinal seam. It is relatively shallow and does no have any creases. I have spoken with every body shop and RV repair shop in my area (chico, CA) and no one has a clue how to fix this,..in fact, i;'ve been told by more than one party that it simply can't be fixed. Any information to the contrary would be appreciated. If it can't be fixed, I need to attach a value to the damage. In terms of a straight vintage airstream that is no longer straight, what might that be? Any info much appreciated. Thank-you
Deborah Penn is offline   Reply With Quote
Old 01-24-2006, 05:46 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums, I wish your first post could be about a happier event.
If you can't use a large suction cup to pull the dent out (doubtful, from your description), you will need to get the damaged segments replaced. You can go to Inland RV's website, (www.inlandrv.com) and check the prices they have on their individual segments. Note the price does not include installation.
There are several RV shops in your general area that can install the segments for you, although it is an expensive job.
Good luck with it.
Old 01-24-2006, 05:47 PM   #3
baxter's Avatar
1969 25' Tradewind
1994 35' Land Yacht Diesel
port saint lucie , Florida
big dent
Hi Deborah, my husband fixed a dent on our 1969 tradewind, believe it or not with a bathroom plunger. It's worth a try. Good luck
baxter is offline   Reply With Quote
Old 01-24-2006, 06:00 PM   #4
Images: 59
Deborah,
The best guy in the world to help you is Kent White. He does aircraft restorations and he teaches courses in how to build anything out of aluminum. He is a short distance from you in Nevada City.
He may not be able to do the work himself, but he could direct to to a local aircraft repair shop that could do the job right.
Forget going to a body shop. Aircraft mechanics have all the right tools.
Here's his website: http://metal-working.com/index.php
Old 01-24-2006, 06:16 PM   #5
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Harbor Freight
Go to www.harborfreight.com and search keyword suction. Try one of these, as I have and they work pretty well. Good luck.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 01-24-2006, 06:41 PM   #6
Uberlanders's Avatar
1968 26' Overlander
Wenatchee WA , Cape Cod
I hope Campcollector chimes in here....he had to fix his brand new trailer after a tree fell on it while they were sleeping in it. Lawncondo had a neighbor trim a tree onto her trailer.
As far as the value of your trailer you can go to www.vintageairstream.com . He has a pretty extensive list of how to price a vintage airstream based on what it has or has wrong with it.
Jim & Kathleen
1968 Overlander - WBCCI #5793
Uberlanders is offline   Reply With Quote
Old 01-24-2006, 08:56 PM   #7
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Cool Just thinking legally......
Hope you are charging the well drilling company for all the repairs.....
Sorry, my former insurance claim/lawsuit/damages brain cell just kicked in.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 01-24-2006, 09:52 PM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You say the dent is centered around a segment split line. If the suck cup does not do the job you might try the glued in place hooks like they take dents out of cars with. You would have to cement a number of them centered around the middle of the dent and then make a rig or park the trailer close to something big that you could attach a line to and put a pulley system on to slowly pull out the dent as you carefully pound with a rubber mallet around the edge of the dent. If that fails you might try drilling out a numbr of rivets at the segment edge and put some wood screw hooks in them and then pull with pulleys as above. Then put the rivets back in using Olympic rivets. Alot depends on if there was any metal stretching that occurred when the dent was made. If the metal stretched nothing will get the dent out. I do not believe there are any interior ribs in that area so I do not think you can push from the inside.
Old 01-25-2006, 04:50 AM   #9
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
I have to agree with Silver 67. Go get the estimates to replace the panels and present the bill to the drilling company's insurance company. Then go have your trailer repaired with new panels. That's why they have insurance.
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 01-25-2006, 04:58 AM   #10
robandzoe's Avatar
Plymouth , New York
Ding King also
I used the Ding King as well on dents - it works well on Airstreams, not on Argosys as the paint the Argosy pulls off before the dent pops. I'd get a panel repair estimate still and present it to the well driller too...and if you just decide to pull the dents, you've got something in your pocket for the damage they did!
Rob
Plymouth, NY 13832
Courtesy parking
Old 05-28-2008, 10:30 AM   #11
2001 19' Bambi
Ashland , Oregon
Wow, this is a two-year old thread. I just started a thread about a dent in my Bambi and was interested to see the replies on this one.
So, how did this one work out?
Muddy Waters is offline   Reply With Quote
Old 05-28-2008, 11:52 AM   #12
1993 21' Sovereign
We don't know, the person that started the thread never came back.
Old 05-28-2008, 01:00 PM   #13
Ottawa , ON
Just emailed her to ask. We'll see if the address is current.
Old 05-28-2008, 01:26 PM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Basketball
Hey Terry, was it you or someone else who used an underinflated basketball to push out a dent from the inside?
Paula
Old 05-29-2008, 09:39 AM   #15
2001 19' Bambi
Ashland , Oregon
I loved that idea and would try it but can't access from the inside of the A/S.
Old 05-29-2008, 09:44 PM   #16
Ottawa , ON
Well, to this time, no reply from the OP.
Old 05-30-2008, 10:54 AM   #17
2001 19' Bambi
Ashland , Oregon
We picked up our trailer yesterday from being serviced and though they tried to get out the dent, only part of it came out. Oh well. We'll just have to live with it or try our own solutions, some of which will based on the advice given on here.
The saga continues.
Old 06-07-2008, 10:34 PM   #18
Ottawa , ON
Never got a response, nor any "no such email" message return.
Seems we will never know!
Old 06-08-2008, 07:42 AM   #19
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
After trying the above if it didn't fix the problem, you could take out the interior endcap and try pushing and rolling the dent from the inside. I would guess you would be taking out the interior skins anyway if you need to have segments replace. A posted photo would help.
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
First Big job.updating toilet from chemi to real rheadhuntress Sinks, Showers & Toilets 2 04-19-2004 06:08 PM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
