Old 07-01-2006, 01:04 PM   #1
Unhappy Help Finding battery/electrical switch Sovereign 1979
Hello All,
For some reason the site thinks I'm a first time member even though I've been a member since 2004. so it's directed me here. I have a Problem.
I am selling my 1979 Sovereign, (long sad story) and the couple selling the Airstream are not trailer people. I have a really dumb question, but I'm out of state and don't have the manual in front of me. Where is the switch to change the power from battery to electric power? They can't find it and I don't remember, as I'm sure it's not the same as on my 1966 Caravel.
Thanks!!
Margaret
mstratton is offline   Reply With Quote
Old 07-01-2006, 01:22 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 has no switch. When you plug it into shore power, you are on shore power. Unplug the power and the battery takes over. BTW, your profile shows you joined the forum on 01-17-2003. It does show that this is your first post, Welcome to the forums!
Richard
Old 07-01-2006, 01:25 PM   #3
Now What?
Hi,
OK, well when they plug it in it's not doing anything, what is the next step in troubleshooting?
I really need to sell this trailer today if I can.
Margaret
Old 07-01-2006, 01:38 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Ok, step by step:
1)Does the outlet from your house you are plugging in to work?
2)If yes, does the AC outlets or air conditioner work?
3)If yes, you have AC power.
4)If no, check your ciruit breakers for the AC voltage. Check your electric cord from trailer for damage. The AC part is straight forward and if the breakers are reset and the cord works, then you must have damage wires inside the camper.
5)Is your battery charged? If so, why do you think nothing happens? Do the DC lights work? Does anything work, like the water pump or the fans? Check your DC fuses. If the battery is charged but nothign works, then you have fuse or wire problems.
6)Unhook the battery, plug in the coach. Do the DC lights and the other stuff work?
7)If not, check your fuses in your Univolt. Are they bad?
8)If they are not bad, your univolt is malfunctioning. This is pretty much a nonrepairable piece and would need to be replaced. Typical cost $125-$200.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 07-01-2006, 01:52 PM   #5
OK,
All sounds good, I'm not at site, am telling them over the phone. No battery in the trailer, where is the breaker box? In the closet? Tha'ts where the Caravel is. Where is the Univolt? Where is the fuse box?
Hi John,
Wow, thanks so much for you assistance.
Sincerely,
Margaret
Old 07-01-2006, 02:19 PM   #6
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
Hope you found the switch
We finally have out water running but can't get any water in the shower. Any ideas?
Alice
acrane is offline   Reply With Quote
Old 07-01-2006, 02:28 PM   #7
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Originally Posted by mstratton
OK,
Hi John,
Sincerely,
Margaret
Hopefully someone with that year knows, I don't. But good luck!
John
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 11:24 AM
1979 Sovereign smily 1974 - 1979 Sovereign 8 03-02-2013 08:22 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
