Old 11-20-2009, 08:34 AM   #1
1975 25' Tradewind
Summerland , British Columbia
Hello new project
Hi I'm new here although I've been watching the forums now and then for a little while. at any rate we have taken the plunge and now have a new project. 1975 25' airstream. It has been parked for many years on the west coast in the forest but under cover. I will have to tow it back home in December (snow storms + mountains) and I'm anticipating replacing the tires and going through the lights before we leave.. just wondering what else could give us a problem. Are the wheel bearings difficult to quickly re-pack? Anyway here is a picture... the shell is straight with only a minor dent on the bottom front. Any information would be appreciated. it looks like I need to load my photos to flickr or something like that to post?
Cheers
keithmac is offline   Reply With Quote
Old 11-20-2009, 08:41 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums.
A 25' 1975 Airstream is an excellent choice, but I might be a little bias.
Instructions on posting pictures from your computer are located in this thread:
http://www.airforums.com/forums/f138...ics-44928.html
Richard
Old 11-20-2009, 08:50 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
If you are going more than a couple of miles, new tires are a must. Also, if you will be traveling at highway speeds, trailer brakes are essential. There is a good chance that the trailer brakes may not be operation after the trailer has set up for a number of years. You will also need a trailer brake controller for your tow vehicle.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 11-20-2009, 12:16 PM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Leave a day or two early to allow for unexpected preparations
that may be necessary before towing it home. Go slow and be
carefull!
kennethowens is offline   Reply With Quote
Old 11-20-2009, 12:32 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by moosetags View Post
If you are going more than a couple of miles, new tires are a must. Also, if you will be traveling at highway speeds, trailer brakes are essential. .
Brian
Not sure if I personally would use adjectives like "must" and "essential". I would agree with "desireable" and gives you a greater margin of error safety factor. It's your choice, but others (including myself) have towed trailers which have not been moved for years with minimal preparation.
Along that line is the liability factor. You wreck do to the trailer not being roadworthy and it's on you.
How long is the tow?
You can tow just about anything if you go slow and easy. I would be more concerned with having brakes on a Sovereign than a Tradewind, more concerned with big downhills than flat, and more concerned with a dinky tow vehicle. I bring along grease for the bearings if I get an overheating bearing, a spare wheel, tow lights (so I don't have to mess with the trailer lights) , a jack, and tools.
Old 11-20-2009, 12:39 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Wheel bearing are not tough, just messy.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-20-2009, 01:29 PM   #7
Kevin245's Avatar
Wheel bearings are easy. The hardest part to me is removing the wheel, so if your putting on new rubber anyway you're halfway there. If the unit has been sitting around for years I would definitely go through the bearings, brakes and tires before taking on any mountains or winter weather. Just my personal take on towing.
Congratulations on your new Tow.
Regards,
Kevin
Eleanor Roosevelt
Old 11-20-2009, 01:45 PM   #8
1975 Argosy 24
Malakoff , Texas
There may not be a usable spare either. You will want to know
so that you can get a wheel also.....flat tires are no fun...even
worse with NO SPARE!!! If I had to do what you are about to do,
I would have a pickup bed full of assorted tools and stuff.
I suggest the 5 P's
Prior
Planning
Prevents
Poor
Performance
Old 11-20-2009, 04:27 PM   #9
Ottawa , ON
Congratulations on your new investment, and welcome to airforums.com!
You answered "City:" with "yes", by the way. The intent was for you to put a city name in there, so unless you live in a town called "Yes"...
IMHO, on a 34-year-olf trailer, I would most definitely re-do the brakes. But not by putting on a bunch of little new parst, rather, by replacing the entire backplate, which will give you new connections, shoes, springs, magnets, and everything. They're probably all bad, and this will be the cheapest and fastest way to safety. The drums should still be OK, but would most likely benefit from some sanding to remove any rust.
While you do this, take the bearings off (two per wheel, or 4 per axle, if your '75 is like my '74) and re-pack them as per the videos. Wear rubber gloves, unless you fancy washing hands for a day or two to get the black out.
Don't be tempted to fill up the water tank, since if something goes wrong in the plumbing, it will most assuredly fail when you least want it to: on the road!
Hope you have safe trip home, and above all POST PHOTOS of your new rig ASAP, puhLeeze?
ps: Flickr or Photobucket are easier to live with and just as easy to use as the forum's built-in image handler.
Old 11-21-2009, 10:47 PM   #10
1975 25' Tradewind
Wow amazing response here! thanks for the info and suggestions to everyone. Our trip will involve one ferry ride and about 7 hours driving. I hour through Vancouver BC 4 hours of mountains.
Old 11-21-2009, 11:02 PM   #11
1975 25' Tradewind
Ok Photo success... My new slippery slope.. have to fit this in between my car projects and Norton project... and starting new business.. and two year old little guy and wifeepoo... NOT necessarily in that order.
Old 11-22-2009, 09:42 AM   #12
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
With your routing you will diffenitly need operational brakes.
Old 12-04-2009, 08:04 AM   #13
1975 25' Tradewind
Just a quick question I'm trying to figure out if I can just pull the four wheels off my car hauler and put them on the airstream for the trip home. Would anyone know the bolt spacing for wheels on a 1975 25' Airstream trailer? 5x?
Old 12-04-2009, 08:26 AM   #14
1975 Argosy 24
Malakoff , Texas
Sight unseen - I would say "NO". Bolt pattern and
wheel offset being different could result in problems.
Suggestion - Take a hydrolic jack and the stuff
needed to take the wheels off...take all 4 wheels
to the nearest tire shop and put new ST or LT tires
under it. You will have to remove the wheels to
repack the bearings anyway. New tires and repacking
bearings are worth about 4 to 6 hours....then you need
trailer lights too. Go straight down the middle on this stuff
and things should go well for you.
'61 project truckasaurus 1960 - 1964 Overlander 8 03-02-2008 02:18 PM
We have a 'project' 84Sovereign Member Introductions 14 09-26-2007 12:05 PM
A new project crispyboy Member Introductions 12 03-28-2007 03:45 PM
My next project azflycaster Awnings 23 01-20-2006 08:47 AM
New Project Janets Husband General Interior Topics 28 04-21-2005 08:45 AM
