Old 08-25-2009, 02:37 PM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Hello New 71 Overlander Owner
I am in the process of fixing up the old girl. I am needing new tires and just want to check and make sure I am thinking right. I should purchase ST225/75/15 load range D. Is this correct? It currently has 235/75R15 tires and the spare is a 700x15. I do not think the spare rim is any good - it is pretty rusted. I have read that 6 hole chevy truck rims will work or do I need to purchase a trailer rim from one of the Airstream aftermarket parts places? Safety is number one, so I want to do this right. Thanks in advance.
mwells4654 is offline   Reply With Quote
Old 08-25-2009, 02:43 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Welcome to the forums!
While some people run LT tires, an ST tire is what is really called for for trailer service. There are several threads (use the search engine) where those who propose the use of LT (light truck) tires state their case. Some of the arguments are valid, others seem questionable.
On the rims - even though the Chevy 6 holer might fit, there are several reasons not to use them. Your trailer requires a "0" offset wheel, some of the Chevy rims have a marginally too small center hole to fit the Airstream hub, and, most importantly, the weight rating of the rim must fit the weight requirements of the trailer. Trailer requirements are generally more severe (must have a higher weight rating) than the "regular" truck rim can deliver.
Rims from just about any vendor (trailer specific internet sales houses are usually the cheapest) will work, just be careful that the size, offset, and weight ratings meet the original specs.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-25-2009, 03:21 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
There's a lot of good tire information here. Do a search, and start doing your research.
Brian
SuEllyn & Brian McCabe
new owner of a '63 Overlander-help! GKP4570 General Repair Forum 3 11-01-2008 09:45 PM
New 68 Overlander owner Aluminati Member Introductions 54 11-21-2007 07:06 AM
new owner of 69 overlander dragonflyt.o Member Introductions 3 10-09-2007 06:42 PM
Possible new owner of '69 Overlander Hind-Sight Member Introductions 0 06-30-2006 10:51 AM
new owner '72 overlander TimM Waste Systems, Tanks & Totes 8 05-24-2006 12:30 AM
