Old 08-02-2016, 08:32 PM   #1
Zak
Tupelo , Mississippi
Hello from Mississippi!
We are getting ready to purchase our first Airstream! We are so excited to get on the road and meet fellow Airstreamers. What is the best truck to pull a 28 or 30' Airstream? Appreciate any advice.
Zak is offline   Reply With Quote
Old 08-02-2016, 09:14 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Impossible question to answer without testing all trucks produced. Like most things everyone has different taste. That is a big heavy trailer. My opinion is that any 3/4 ton with a proper towing package should do the trick.
MICHAEL
Old 08-02-2016, 10:27 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Ditto on the 3/4-ton pickup recommendation. I like and recommend diesel trucks.
What is your budget for a tow vehicle?
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 08-03-2016, 06:35 AM   #4
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Welcome to the forums.
Dalwyn
Dalwyn is offline   Reply With Quote
Old 08-03-2016, 08:01 AM   #5
Zak
Truck towing
Thanks, I am thinking $50k. Going to look today. F150 looks like it handles 10,400k and F250 up to 12,400, Toyota Tundra 12,500. We want it to pull easily in the mountains for sure.
Old 08-03-2016, 08:40 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Be sure to check the cargo carrying capacity of each TV. I don't know the tongue weight of the coach you are looking at. If it is close to 1,000 lbs. You will be severely limited on what cargo you can carry when the TV has a half ton rating. Don't forget cargo capacity. Each passenger subtracts from the rated capacity as well as luggage etc.
A TV with 1,500 pound cargo capacity towing a trailer with a 1,000 pound tongue weight only has 500 pound left of the rated capacity.
Don't look in a sales brochure for this info. Look at the placard on the door post of each TV you are considering. These capacities are different with different trim packages.
Be sure to get the tow package on whatever you buy.
Old 08-03-2016, 08:54 AM   #7
Central , Mississippi
Welcome to the forum Zac. The vintage of your potential new 'stream will wildly affect the truck decision. A older 30' could weigh 1/2 as much as a newer one, making a possible pleasurable towing experience in the mountains turn into a right lane, flashers on, crawling up a hill night mare.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-08-2016, 10:52 PM   #8
TitansUSA's Avatar
2016 28' International
Nashville , Tennessee
Make sure to do the research on the Tundra. Yes it pulled the space shuttle on TV, but all of my research and interwebs reading put it on the borderline. I had a 2015 CrewMax 1794 edition and it would have probably pulled my new purchase fine, but I was concerned about stopping and/or emergency situations when people are people on the highways. I ended up with a 2016 GMC Sierra 2500 HD diesel with Allison transmission. I barely felt the airstream when I was bringing it home from the dealer. Hope this helps. Just be mindful that all dealer will show you charts and tow ratings. You need to factor in what you are going to add to the trailer, what you might carry in the back of the truck. The 3/4 Ton helps because you go up a class in hitch and springs. In the end you need to go with what you feel your personal storage needs are and how comfortable you are in stopping suddenly, etc. Good luck with your search and decision.
TitansUSA is offline   Reply With Quote
Old 08-09-2016, 09:53 PM   #9
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
www.rvtowcheck.com
The half tons of recent years are more capable than even a decade ago....
Tom
TVKetchum
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 08-09-2016, 10:41 PM   #10
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
Welcome to the Forum!
Remember, it's not just having the power to pull, it's the ability to stop when you need to and keep the "truck leads - trailer follows" relationship intact at all times. You're looking at a couple of big trailers. Never, in the history of trailer towing, has someone in a bad situation said "Gee, I wish I had less truck!".
We started towing our 27FB Classic with a 3/4 ton Dodge with Cummins turbodiesel just because that was the truck we already had. When we upgraded to a new one, with a few more "bells and whistles" I found that, while shopping Rams, there was less than $300 difference between the 3/4 ton and a 1 ton - which gave us almost 2000lbs more load capacity. No brainer. I highly recommend as much truck as you can afford, and make it a diesel. The torque, power, and engine brakes, as well as fuel economy make the extra price worth it - they are bred to haul. Our '15 Ram 3500 doesn't even seem to know it is pulling 7500lbs of trailer!
Tim
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 09-08-2016, 05:25 PM   #11
Zak
We did it!
We pick up our 30' Classic tomorrow! So excited to meet some of the fellow AS folks. Anyone winter in Florida? Any suggestions?
Thanks to all for your input.
F250
Equalizer Hitch
30' Classic
Ken & Callie
Old 09-08-2016, 05:34 PM   #12
Originally Posted by Zak View Post
We pick up our 30' Classic tomorrow! So excited ...
Ken & Callie
I predict a sleepless night...
Post photos!!!
Old 09-08-2016, 10:40 PM   #13
Adiredneck's Avatar
2014 27' FB Classic
Now you need to do a few "shake down" cruises on the Natchez Trace Parkway to Jeff Busby or some other close by campground!
Old 09-09-2016, 03:12 PM   #14
Zak
Bad News on 2017 Classic 😥
Post photos!!!
Well, couldn't pick it up! Two major issues on the inspection: 1) water running down the side of the trailer by the door (air conditioners not draining; upon further tech inspection water was all over the top he feels the return air is mixing with cool air on both air conditioners. 2) could not attach hitch because it interfered with the propane gas line and location of battery box.
They are calling Airstream for solutions.
Hello All! Newbie here just wanted to say Hello! star Member Introductions 4 08-03-2012 10:08 PM
Just want to say hello. So, Hello AirstreamAZ Member Introductions 13 01-10-2007 09:24 PM
Hello hello SeanClaes Member Introductions 9 01-30-2006 07:58 PM
Pulling 2000 34' home from Mississippi w/o WD FireFighter Hitches, Couplers & Balls 23 05-25-2004 02:36 PM
Used Airstream Dealer in Mississippi Raptorrider2001 Our Community 10 09-27-2002 09:08 PM
