Old 04-19-2011, 03:31 PM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Hello everyone from the Buckeye state
We took the plunge last week and picked up a 25' Tradewind twin bed coach. We were staying in North Carolina for a few weeks when I saw it for sale. It is completely origional from what I can tell, but I'm sure it will need a complete redo. I'll put up pics as soon as wifey shows me how.
This won't be our first camper, only our first Airstream.
I'm 62 and out of work, most likely for good so I think this will be a welcome project.
The AS is still in Carolina. I plan to go and pull it home in a few weeks. I'll take some tires with me and get the brakes and bearings checked out before hitting the road.
One question if I may. The shore power plug is a 15A 250V 2 pole 3 wire grounding plug. Can anybody tell me why that is so?
Thanks for the help and hope I can contribute.
Regards, Paul.
Flynavy is offline   Reply With Quote
Old 04-19-2011, 03:55 PM   #2
Gainesville , Florida
Should be 30 amp 120 volt??? or are the vintage dif?? zz
Old 04-19-2011, 04:30 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
I can't imagine why this trailer would have other than a 120 volt electrical cord. Is there some kind of electrical splitter unit in the trailer that brings in 220, and splits it into two 110's?
Brian
SuEllyn & Brian McCabe
Old 04-19-2011, 05:02 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
So, it has 2 flat prongs in the same plane and a rounded ground prong, like the picture below?
My guess would be that someone may have had this trailer hooked up at home and did a home-handyman outlet for it and used a plug and receptacle intended for an old 220V window unit or something like that. It wouldn't make sense for a PO to have modified the trailer to actually use 220V power, there'd be so many things they'd have to change and I don't think they could get an RV AC unit for 220V at all. Then you'd always need an adapter away from home, because any campground would have 30A and/or 50A normal RV receptacles.
The good news is that the 30A 120V RV plugs are readily available, you can buy a plug that can be wired onto the end of your existing shore-power cord, or you can buy a whole new shore-power cord with a molded plug (more durable) and wire it in on the trailer end (potentially more work.)
— David
Old 04-19-2011, 05:32 PM   #5
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Welcome!
Hey Navy,
Welcome to the forums.
fltlevel510 is offline   Reply With Quote
Old 04-19-2011, 05:54 PM   #6
ctdair's Avatar
Oberlin , Ohio here , so not too far from Col. Station. Loudruff is in LaGrange and DanB in Lorain as well as Winestream in Jeromesville. So If You have any questions or need any Airstream help contact us.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 04-19-2011, 06:33 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Paul - welcome. Enjoy your new toy....
Old 04-19-2011, 08:02 PM   #8
1974 27' Overlander
Newark , Ohio
We are new owners of a 74 Overlander and in Newark, Ohio. We have lots to learn and would love to keep in touch with all of you. We have it scheduled to have the wheel bearings packed and brakes checked out on the 27th. Still in the "checking things out" phase.
Crazy Grace is offline   Reply With Quote
Old 04-19-2011, 08:04 PM   #9
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Paul, welcome to the forums. Good luck with your redo and electrical issue.
A Wolverine from up north.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-19-2011, 08:09 PM   #10
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
welcome fellow Ohioan
We are located in LaGrange, only a few minutes away! We have a fine group of Airstreamers that live within a few minutes. We often have driveway rallies at our house. We have full hookups available right here. Several folks have come for their first AS campout!
Larry says that he has a 30 amp/120 RV plug with a pigtale on it if you would like to borrow it to go and get your trailer. PM us and we can talk.
Here a link to the spot that some of us post to when we are off on a weekend campout...hoping that some more of our Airstreaming friends will join us. http://www.airforums.com/forums/f290...tml#post890669
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 04-19-2011, 09:30 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you get it home; this is the proper setup for the shore power, note that it is for RV (travel trailer use only). You should also get a voltage tester to make sure the power source is wired properly. The trailer is 120 volt, not 240 volt.
Name:	Shore Power Hardware.jpg
Old 04-20-2011, 07:07 AM   #12
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Thanks to everyone for the welcome. Looking forward to getting togeather with those close by. It will be a while before the AS is camping ready but we still would like to attend your events if we can.
When I saw that 250v plug on I couldn't understand why it would be like that. Guess I will just take 30A 120V plug with me when we go back to pick it up.
Thanks for the help on the power cord.
Regards, Paul.
Old 04-20-2011, 07:19 AM   #13
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Brian
Don't understand it either. Thougth maybe they were putting 220 to the AC. Can't say about the splitter as it's not here to look at. If it does have some sort of splitter it won't hurt to put 110 to it, some stuff just won't work.( I think ).
Old 05-01-2011, 05:50 PM   #14
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Welcome to our Ohio Group. A mighty fine group if I do say so. I think what you have seen is the Rating on the plug,But it must be set up like the picture TG TWINKLE has posted. HOPE to see you somewhere here this summer.
I didnt think anyone was still using this thread. IM glad to see its still active.
ROGER
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
2011 Florida state rally info RickDavis WBCCI Forum 33 10-01-2011 09:57 AM
McGrath State Beach in California to Close OB Bambi Airstream "In the News" 0 04-15-2011 07:55 PM
Bryce Canyon to Dead Horse State Park (Moab) JGB On The Road... 6 02-27-2011 08:57 AM
Ward Charcoal Ovens State Historic Park - Ely NV JamuJoe On The Road... 0 02-17-2011 10:07 AM
those state maps The Driver On The Road... 7 01-14-2011 07:39 PM
