Old 05-14-2006, 11:47 AM   #1
Wareham , Massachusetts
Hello
Hi Folks, my name is Jack, and I am new to this forum business. Please bear with me while I learn. We are hoping to buy a used Airstream and would like to know if there are any model years that are better than others.
jack02571 is offline   Reply With Quote
Old 05-14-2006, 11:53 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
hi jack and welcome aboard!
i'm partial to the 90's trailers, i think all years have plusses and minuses.
you've found the right place to do your research!
john
you call them ferrets, i call them weasels.
Old 05-14-2006, 12:10 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Hello
Greetings Jack!
Welcome to the Forums!
With the number of Airstreams on the road, there is a floorplan out there that will suit nearly everyone. There was some commonality to the designs for various eras. For instance, the rear full or 3/4 width bath was fairly constant from sometime in the late 1950s throught the late 1970s to mid 1980s. Beginning in the late 1970s, side and mid-baths became more common, and by the 1990s most coaches had some variance of the side or mid-bath.
My advice would to be to look at as many coaches as possible to get a feel for the floorplan and era that best suits your taste/needs/wants/desires. Then it will be an issue for shopping for the coach that is in the best condition in your price range and desired model. Sometimes, the exact coach will nearly fall into your hands without an excess of effort; while for others it can take months if not years of searching. With my Overlander, it was about nine months of searching; while it took a bit longer to acquire my Minuet as I was in no particular hurry to find a coach since I only wanted a smaller coach for weekends and shorter trips.
To get a better idea of what some of the Vintage coaches are like, you might want to spend some time looking through the website linked below:
http://www.vintageairstream.com/archives/index.html
http://www.airstreammotorhomes.com/trailers/index.html
In addition, if you haven't decided that your purchase must be an unpainted Airstream; there is the option of the Argosy -- the Argosy has some floorplans as well as features that either never appeared on Airstreams or appeared sometime later on Airstreams.
Good luck with your research and investigation!
Kevin
Kevin D. Allen
AIR #827
Old 05-14-2006, 12:35 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums Jack. Wow did you ask a loaded question. Usually the model year that you own is the best.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-14-2006, 04:25 PM   #5
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
holding tank configuration
Jack,
I love the vintage trailers but I'm partial to the ones with separate fresh, gray and black water holding tanks. Some of the older trailers "vented" directly to the environment (no gray water tank).
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 05-14-2006, 05:05 PM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I like the mid '80's to mid '90's for the regular width trailers and the '95's and on for the extra 6" width of the widebody trailers.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
