Old 10-03-2015, 10:15 PM   #1
1966 24' Tradewind
garberville , California
Getting started on the floor
Of my 1966 Tradewind Land yacht. scary stuff. I can't afford much but am going to piece this out. Any suggestions concerning the screws that hang from previous subfloor install, should I cut them with ? Also to get sub floor to the frame (after cleaning rust ect) how does one get the subfloor to the frame? I read here no. 12-24 machine screws doews this sound right? I am just bumping along solomente here
1966trade is offline   Reply With Quote
Old 10-04-2015, 01:47 AM   #2
1979 23' Safari
Wayland , New York
Grind the ones that don't come out with a grinder.
Screws for putting floor back in;
http://odmrv.com/catalog/index.php?main_page=product_info&cPath=79&products _id=638
Think that's what you were asking.
Old 10-04-2015, 06:19 AM   #3
CraigFulton's Avatar
1962 22' Safari
Saint Petersburg , Florida
Images: 53
Send a message via ICQ to CraigFulton
I am doing this very job myself and have a post in the floor and frame section titled "termites are everything..."
If you completely remove the floor the shell drops on the frame. You'll need to remove the belly pan to cut the bolts on the outer edge. Then lift the shell to get the new subfloor in. Lay underneath and drill the holes through the wood from the frame holes. Use elevator bolts and nyloc nuts to hold the floor. Lower the shell back down and get the edges bolted. Then put the belly pan back.
I thought this would be a much simpler job myself but that's the simplest way to do it right. Vintage Trailer Supply has the elevator bolts and belly pan rivets.
http://youtu.be/avRIpHurdCc
CraigFulton is offline   Reply With Quote
Old 10-04-2015, 06:19 AM   #4
1962 22' Safari
Images: 53
I cut all the old bolts out with a sawzall and metal blade.
Old 10-04-2015, 08:52 AM   #5
1972 23' Safari
Camas , Washington
Welcome
check out the replace the subfloor and or frame section, lots of good advise.
Repairing/Replacing Floor &/or Frame - Airstream Forums
Pams72 is offline   Reply With Quote
Just getting started bawjr1 Member Introductions 2 07-28-2007 10:48 PM
Getting Started - plan to fulltime MandD Member Introductions 0 05-28-2007 06:04 PM
Just getting started. Relentless Member Introductions 9 03-03-2007 10:16 PM
Getting Started in RI Viper Member Introductions 6 03-18-2006 07:42 PM
help with getting started popmize Forum Admin, News and Member Account Info 5 08-21-2002 06:29 PM
