Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 01-29-2007, 12:00 PM   #1
Cullowhee , North Carolina
Farider1
The title says it all. I LOVE to travel. Have been absolutely everywhere in the lower 48 but completely new to Airstreams. Purchased #7712 which was covered in kudzu and sitting in a yard here in Jackson County, North Carolina. The trailer (a 1973, 27' Overlander) was dry inside but full of mildew and evidence of higher order life forms (4 snake skins and several mouse nests). I have a lot of renovating to do. Right now I'm concerned about its four very flat tires which have deteriorated and must be replaced along with almost every other piece of fabric and rubber in it. I plan to jack the whole thing up and rest it on a platform of railroad cross-ties during the restoration. I'm pretty ambitious and expect to dig into the floor and bellypan. Any special comments on how to do this will be appreciated.
Farider1
wbonds is offline   Reply With Quote
Old 01-29-2007, 12:10 PM   #2
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Welcome!
Welcome, and congratulations for saving another classic Airstream from the elements and critters...
You'll need a few key supplies to insure your project is successful:
1. A Money Bin (See Scrooge McDuck..)
2. A Hydraulic Lifter (gently removes shell from frame and removes when done..)
3. A Combo Welder/Grinder/Epoxy Sprayer that can fix problem frames in 30 minutes or less
4. A case of "Tank Magic" to enlarge, relocate and seal your water and waste tanks to suit your needs
5. A source for "Wallywood", which is rare flexible hardwood, easy to fabricate into curved furniture and cabinetry using simple hand tools...
If you have trouble acquiring these, be sure to use the "Search" tab above to at least learn from others how they accomplished the same kinds of restorations using less sophisticated supplies.. Good luck, and let us know how it goes...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-29-2007, 12:18 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Welcome to the forum! Call us in five years and let us know if you still have your AS! Sounds like you have yourself a full off frame restoration. The Full Monty as it's called around here. First you need to post a bunch of pictures, use your search function, then win the Lottery! You are going to make some great friends here and ou will probably find at least five correct answers to every question you post. Have fun and make friends!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-03-2007, 11:05 PM   #4
airstreamers's Avatar
1979 28' Airstream Excella 28
southwestern , Michigan
sounds like quite an undertaking, but it will be very worth it in the end and saving this great old trailer will be a fulfilling challenge. that kudzu is wicked stuff and it just keeps taking over more and more. anyway, glad you found a treasure in it. best of luck and as always, pictures, please. that way we can all take the journey with you. of course, it will be easier from here! have fun!
airstreamers is offline   Reply With Quote
