Old 12-10-2005, 12:03 AM   #1
1980 28' Excella II
bainbridge island , Washington
exciting but issuses
hello out there: bought `81 28` excella in march. Towed it from arizona to washington state with no problems. Have put on about 3000 mi so far and have found ALL four tires are rubbing on their sides against wheel wells. have worn one hole so far with no fire. Am using st225/75/15 goodyears. Will be checking backspacing soon. Any thoughts would be appreciated.
thanks, jerry
woodnhair is offline   Reply With Quote
Old 12-10-2005, 12:38 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
thanks, jerry
Check the wheel offset first, and then the axle condition. Does the trailer ride very low? Can you take some pictures of the wheels adn teh damaged areas and post them here?
Uwe
www.area63productions.com
Old 12-10-2005, 07:07 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I think that year trailer originally came with bias tires. Width of radials is different. Where is the wear occuring? (on the outer sidewalls?) You may need to go back to bias. Are they the original steel or alumium rims? May have the wrong wheels on it.
Old 12-11-2005, 01:20 PM   #4
1980 28' Excella II
exciting but issues
First of all, trailer was made oct 24 `80 and reg. says `81.
Wear is on the inside portion of well against a 20" x 12" aluminum sheet that is on all wells near all tires............original?
wheels not steel, look like alum.
not sure how to measure backspace yet but from backplate of wheel to front side [thru lug hole] is 9/16".
wear on tires is just 1/4 " below where tread starts.
am investigating weak springs/shocks.
tire pressure is 44# for specs that say 50# max.
will get back when i have more, thanks for input
« arnie | Top | yo! »
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 07:38 PM
Forum rally in September Fort Desoto in St. Petersburg overlander63 Forum Rallies & Meet Ups 130 10-07-2005 08:38 PM
total overhaul need advice nevisstudio Interior Restoration Forum 40 04-24-2004 02:51 AM
Picked it up and was it EXCITING!!! (Long post) dinoburb On The Road... 14 03-07-2003 05:17 PM
Calendar idea COArgosy78 Our Community 22 11-30-2002 01:21 PM
