Old 04-26-2006, 05:31 AM   #1
Elk
1970 27' Overlander
Reno , Nevada
Elk needs bearing seals
New to the Airstream world
Hello everyone
Need wheel bearing seals for 1972
I do not have the coach in possesion yet just getting ready to pick it up over the week end
Any ideas would help
Rod
Elk is offline   Reply With Quote
Old 04-26-2006, 08:46 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
If you need bearing seals, you should repack the bearings. Furthermore, if the seals leak, your brakes have probably been ruined. Brake shoes soak up the grease. A new loaded brake plate for 12" drums is around $75 each. Seals can be purchased at NAPA or any reputable auto parts store. I don't have the part numbers handy, or I would relay them to you. Do a search on this website.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
Seals and Weatherstriping niftypkg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 10-29-2002 09:40 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
Window Seals niftypkg Windows & Screens 0 06-14-2002 06:39 PM
