Old 11-02-2006, 05:19 PM   #1
1982 34' Limited
Chatham , Ontario
electric jack is dead!
We had the need to get the Airstream out of the driveway in a hurry, and when we plugged the trailer into the Durango, the jack wouldn't move. It has before obviously, or we wouldn't have gotten it into the driveway. The jack is stuck in the down position. Is there any way to override it with a battery, or something to crank to get it moving? I checked the threads, and didn't find this problem anywhere.
frank n'shar is offline   Reply With Quote
Old 11-02-2006, 05:29 PM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
you can take off the rectangular cover, I think you need a hex head to do this. There is a groove in the shaft to insert a manual speedwrench tool. Mine came with my trailer. move it by hand. When you figure out the electrical dillema and want ot readjust the jack there is a procedure to sync the thing.
doorgunner is offline   Reply With Quote
Old 11-02-2006, 05:30 PM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
want to try the chat room I'll be there
Old 11-02-2006, 06:14 PM   #4
1982 34' Limited
Chatham , Ontario
computer spaz here!
Can't seem to figure out how to get into the chat room. No matter, you seem to have left anyway.
Old 11-02-2006, 06:21 PM   #5
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Frank n'shar, I feel your pain, but don't have the experience yet with an electric jack to offer intelligent help. What brand is your jack? Do you know if a manual crank handle came with it? Someone else with the same brand may be able to help.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 11-02-2006, 07:27 PM   #6
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Sympathy
When we returned from the fall leaf lookers rally I was doing the full up then full down, to drain my fresh water tank, when my electric jack thought it would be funny to only allow the trailer to go up and not down. I left it for a day in the full up right position and the next day when I went out to work on it I found that the toggle switch on the bottom was loose. Tightened it up and now it works, but I would like to hear if anyone has taken theirs apart and tried to overhaul it?
I have used my car jack to raise the tongue on a U-haul trailer that had a stuck manual jack; maybe you could use your car jack to raise the tongue up enough to get it either hooked to you tow vehicle or get the weight off the electric jack and see if that will help you get the jack unstuck or at least retracted enough to make the move you need to make.
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
Old 11-02-2006, 07:52 PM   #7
1982 34' Limited
Chatham , Ontario
Well that was a good start, but we tried that.
When we manually jacked up the trailer with a car jack enough to get the hitch underneath, we thought that we were really clever - untill we lowered the car jack to make the tow, and the unretracted jack dug into the ground when the tongue weight pulled down the back of the Durango.
So with a dump truck of rapidly cooling asphalt in my driveway, we used the car jack to jack it up again , unhitch the Durango and hook up the paving contractor's F150, which when levvelled off, left us enough (not much)clearence to pull the camper across the street to the neighbor's driveway. Trouble is that the contractor unhitched the f150 and drove away - leaving the air stream in the nieghbors driveway. Not a good long term solution.
Old 11-02-2006, 08:06 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, If your tongue jack has a light on it like mine, see if the light works. If not, there should be an inline fuse on the wire from the jack to the battery. Maybe only a fuse? Or manually raise or lower the jack. Last, just take the thing off and get it repaired or replaced.
Old 11-02-2006, 08:14 PM   #9
steelbird312's Avatar
1956 22' Safari
2013 31' Classic
Crossville , Tennessee
Images: 11
Hey folks. What was said earlier is indeed the answer to your problem-short term. Take the top off your jack. There will be a tube that looks as if it has two groves, 180 degrees from each other. A handle is made, (and should be in your trailer somewhere, look in the box built into the tongue) that will look like an L with another leg down, or if you know what a speed wrench handle looks like. It will have a hardened pin through it. That handle fits into the tube, the pin fits in the two grooves, allowing you to turn it up or down.
Good luck.
Oh, and tomorrow, check to see if your fuse is blown; then check to see if it has a GOOD ground as well as a good hot wire. Yes, the jacks can be rebuilt, however, they rarely go immediately bad as yours has. I would bet on a blown fuse or a loose or cut wire.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 11-02-2006, 08:27 PM   #10
1982 34' Limited
Chatham , Ontario
Oh there's bound to be a wiring problem!
The first time Frank plugged it into the Durango, it blew a fuse immediately. Changed the fuse, and got it home from the dealer. Pulling it from the storage lot to here didn't work on the dodge van, so he came back and got the Durango, and pulled it into the driveway.
We know that the rest of this unit has major electrcal issues, including the whole 12V system, and lots of bonus wiring done by the PO instead of fixing the problem.
We'll get to the wiring after we get the window leaks under control - crawling before walking I suppose.
Really appreciated the detailed description of the manual process - thanks for the many details. We try that tomorrow after the ret of the driveway gets paved.
Old 11-02-2006, 09:14 PM   #11
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I don't have anb electric jack....yet. However, I carry a bottle jack just in case my manual jack breaks.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-03-2006, 06:22 AM   #12
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Mine is also dead.
Iím glad this question about electric tongue jacks came up. I know there have been other threads about repair but canít find any that address my problem.
The elec Walker jack on my recently purchased í67 TW makes a clicking noise when I push the switch but doesnít work. I suspect something is seized up inside the head. There is no manual crank handle. I discovered that by cutting the wire and loosening the 2 allen-head set screws, I can manually rotate the head to raise/lower the tongue.
Iíve checked with 2 RV shops to see if they can fix it but they want $100 minimun for labor. Iím going to take the head apart to see if I can find the problem but does anyone know where to buy parts for this old Walker jack? A parts schematic would be great.
These electric jacks are great,,,when they work.
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
