Old 01-20-2006, 06:52 PM   #1
Exclamation drapery hardware for '62 & '63 Bambi
Does anyone know where I can find the metal hardware that rivets to the inside walls and the attachments for the drapes? Would the plastic eyelets that work on a '64 Overlander work on these frames and where could I find these?
thanks,
carol
irl & carol is offline   Reply With Quote
Old 01-20-2006, 08:02 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Hi and welcome to the forums. You might use the search tool in the upper right hand corner as a starting place.... and hopefully, some one will chime in with some help..
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-20-2006, 08:20 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
irl & carol,
greetings~
Try this link..if you don't find what you want on this page..try moving around abit to find the right one for your needs..
http://www.go-rv.com/coast/do/catalo...47&pageNum=196
For example..you see the 196 on the end of the url?? Just change it to 195 for example..
Good luck~!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 53 08-14-2018 06:04 PM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 04:53 PM
Rusted through hardware on step - source? casarodante Steps 7 07-01-2002 10:48 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
