Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 06-02-2006, 12:51 PM   #15
buspawn
Profile:  1957 22' Flying Cloud
yes , Washington
Question yay!!
i think i got it; hope this works... the links were beyond helpful!!! thank you AGAIN. i downloaded the 'pic sizer option' as suggested by 'chuck' since it seemed the easiest most straight forward route.. so we shall see....
edit:
oops! they are really big still. i'll work on that. but at least yall can get a visual on what im working with here...
Name:	airstream 57 001 (Small).jpg
ID:	21838  Click image for larger version
Name:	airstream 57 006 (Small).jpg
Name:	airstream 57 007 (Small).jpg
ID:	21840  Click image for larger version
Name:	airstream 57 008 (Small).jpg
Name:	airstream 57 003 (Small).jpg
ID:	21842  Click image for larger version
Name:	airstream 57 010 (Small).jpg
Name:	airstream 57 011 (Small).jpg
ID:	21844  Click image for larger version
Name:	airstream 57 012 (Small).jpg
Name:	airstream 57 014 (Small).jpg
ID:	21846  Click image for larger version
Name:	airstream 57 015 (Small).jpg
buspawn is offline   Reply With Quote
Old 06-02-2006, 01:15 PM   #16
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
See, patience pays off! Glad you were able to find a program that works for you ~
Now. it appears you will need another dose of patience during the restoration of your trailer. The problem with parting out trailers is, they have to be "beyond repair" in order to do so. Most trailers out there can be repaired, by someone...so hopeless ones don't come around too often. There are occaisionally some that come up, but having be the same year/model/parts that you need is another story, especailly panels. That's where the patience part comes in...
Cherokee RV is a great resource...we are fortunate to have them in our own backyard! If they can't help, keep trying...
In the meantime,you may want to take your interior panels off and straighten the exterior ones out as best as you can from the backside, then straighten the interior ones and re-install them until the "perfect donor trailer" comes along ~ Maybe you will be lucky enough that the results are successful and you won't need a donor.
Good luck in whatever you decide to do...we're all here for encouragement!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Airstream Height Earl Winterizing, Storage, Carports & Covers 25 03-22-2008 09:34 PM
Fuel Consumption: (curious) Drew Airstream Trailer Forums 15 12-26-2002 07:28 PM
Just Curious Why? 53flyingcloud Our Community 21 12-12-2002 09:47 AM
No water to toilet Oak Sinks, Showers & Toilets 13 11-01-2002 07:31 AM
Coast To Coast Rv Resorts ALANSD On The Road... 23 10-29-2002 02:45 PM
