Old 08-29-2009, 12:44 PM   #1
frankfarmer's Avatar
1992 34' Limited
Snead , Alabama
Converter, battery charger out, any help???
New owner, one month, 1992, classic, 34 foot. All has been going pretty well understanding all the sysytems.
A day or so ago the converter stopped working, batteries down. Bought new batteries. Current line is good all else works OK. Switch for converter in same on position.
Read manual, looks like a big job to remove rear sofa to even get to this area.
Any help/advise greatly appreciate!!!!.
Frank Burgett, Mountain area of Guntersville Lake, Alabama.
Thanks, have great day.
frankfarmer is offline   Reply With Quote
Old 08-29-2009, 12:53 PM   #2
Central , Mississippi
On my '91 the charger is between the battery boxes and is visible by removing the drawer under the foward sofa. There is a power switch behind the sofa, looks just like a wall mounted light switch, that was set up to power down the converter. Mine is no longer connected
Mine has been replaced by the PO, the new one was place back in the original position.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
New Xantrex Converter/Charger 68 Overlander Commercial Listings 6 07-25-2012 07:01 PM
rv converter/charger j&smarin Batteries, Univolts, Converters & Inverters 3 02-22-2009 03:04 PM
converter / battery charger somedaysoon Batteries, Univolts, Converters & Inverters 3 12-28-2008 10:56 AM
New Converter / Charger on the block 68 Overlander Commercial Listings 19 03-07-2007 10:54 AM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
