11-26-2006, 05:40 PM
2007 19' International CCD
Los Angeles
Checklist
Hello Everyone........I'm a new Member and also a new owner of a 19' Safari. I would enjoy hearing from someone about checklists before hooking up and when parking the camper....also Ihave it parked in a storage lot and it's already dirty.........should I wax the rig or just wash it??
Best to you all, Robert
11-27-2006, 11:53 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Welcome to the Forums!
As far as checklists go, here's a couple to get you started: Checklists
Most everybody kinda develops their own after going through the process of hitching up & moving down the road a couple of times. You may find some other lists by performing a search using "checklist" as your keyword.
With a new 2007 trailer, a good wash and wax would probably be in order, especially if it's never been waxed - gotta protect that clearcoat. I'm not as familiar with the "care & feeding" of the new ones...but many here online are. Hopefully someone will chime in. I believe Airstream recommends the Walbernize line of products. Personally, I would stick with their recommendations. Again, if you search using "Walbernize" as your keyword, it'll give you some rading material to catch up on until someone else posts a direct reply.
Shari
11-27-2006, 12:17 PM
Roseville
Search probably for "checklist" and you should find many.
Here is what I use when departing:
Check List – Pulling Out
- Vents closed
- Outside thermometer retrieved and stowed
- Hot water heater, water pump off
- Cupboards latched, loose stuff secured, table secured
- Door double-locked
- Awning secured
- Stabilizers up
- Chocks, blocks stowed
- Dump hose, electric cable, TV, water hose stowed
- Storage lockers closed
- Forward windshield secured
- Steps stowed
- Sway bar & torsion bars attached
- Chains, breakaway secure
- Receiver locked to truck, coupler locked to hitch
- 7-pin cable locked
- Truck mirrors extended
- Trailer lights (running, brake, turn) OK
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
11-27-2006, 02:10 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Check List – Pulling Out- Vents closed
- Awning secured
- Stabilizers up
- Steps stowed
Good list, but I'd add, "wind down TV Antenna", "put extra ice in fridge/freezer to keep food cold", "fully raise the hitch pin"
Paula Ford
12-17-2007, 09:52 AM
2008 23' International CCD
Cordova
, Tennessee
Thanks to everybody!!
I have found these checklists to be a great help for me. I am just starting out and was about to draft my own list. See you around the campfire!
12-17-2007, 10:16 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
You need two lists...
1. Items to pack before the trip
2. A Wal-Mart list for items you forgot.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
12-17-2007, 01:08 PM
2005 30' Safari
2022 27' Globetrotter
River Forest
Here is the list I keep in my Suburban... Rick Hitching Up and Pulling Out Outside- Water & electric disconnected & stowed
- Rear trailer jacks up
- Front trailer jacks up
- Awning closed – knobs tight
- Stone shield down
- Confirm TV antenna down
- Confirm vents closed
- Propane off (if not using refrigerator)
- Hitch up being sure to check the following:
- Insert ball
- Insert hitch pin, clevis pin
- Insert sway bars
- Hitch up
- Hitch locked – confirm tight
- Connect sway bars – 4 loose links on sway bars
- Sway bar lock pins
- Connect break-away cable,
- Connect electrical umbilical cord
- Jack foot off & stowed
- Remove wheel blocks
- Pull forward slightly, remove level blocks and stow
- Storage doors locked
- Step up, door locked
- Check the lights (stop lights, turn signals and running lights)
- Check electric brakes
Inside- Heat or A/C off
- Hot water tank off
- Water pump off
- Switch refrigerator to gas (or off)
- TV antenna down
- Vents closed, turn switch to 0 for off
- Bathroom vent closed
- Top cabinets closed tight
- All door knobs in locked position (in)
- Rear drawer in locked position
- Windows closed
- Kitchen counter items stowed
- TV stowed
- Lights off
Long Term Storage- Refrigerator/Freezer doors open
- Battery switched to off position
- Drains plugged
- Curtains closed
- Battery saver on
2005 30 Bunkhouse
2012 Chevrolet Suburban 2500
Honda 2000
Air #99
WBCCI #8895 (Grandpa's number from the 1960's)
12-19-2007, 11:49 AM
Cordova
, Tennessee
Thanks RG!!
This is exactly what I was looking for! I really appreciate your help!!
DM
