Old 11-10-2006, 04:29 AM   #1
1984 31' Sovereign
Newberry , Michigan
Cam Chisholm
I am rebuilding a 1984 31ft airstream can any one tell me where i can get a drawing of the frame.
C. Chisholm is offline   Reply With Quote
Old 11-10-2006, 07:56 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Cam -- Welcome to the Forums! There have been infrequent postings of low resolution scans of old frame diagrams for the odd model here and there. I don't know any way to pull those up. Are you just starting the process or deeply into it? 'Rebuild' can mean any number of things -- at the most extreme a "shell off" restoration of the frame. I believe Ultradog has remade frames directly on top of the old one as a pattern (also see this). Other images are here and here.
Can you be more specific with what you're seeking? Thanks.
5 meter Langford Nahanni
Old 11-10-2006, 11:14 PM   #3
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Welcome to the forums! You might look through the members list to see who has an Airstream like yours and send them a personal message if you don't find the answers you need... or look for threads that have 1984 Soverigns... you will find what you are looking for somewhere!
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
