Old 10-06-2018, 06:47 AM   #1
Ft. Thomas , Kentucky
Buying an Airstream?
Morning‘
I am considering buying an airstream. I do sheepherding with my four Border Collie‘s and I’m on the road a lot. I want something that will not shake apart in a couple of years. I have been traveling in a 1999 Scamp for the last 10 years, I just sold her on Thursday. Question? Are airstreams worth the money? I do camp in farm fields and mostly boondock. The farm fields are nothing horrible to drive in, mostly level fields. I have been looking at all types of campers, just very concerned with other brands of campers as they seem to be so mass manufactured at this point and I am concerned about the quality/quality control. Even with looking at the new ones, I find major things wrong while they are just sitting on the lot. I definitely want a double axle as I had a blowout on the expressway with my single axle three weeks ago. All‘s well that ends well and it ended well, but I do want a double axle. I pull with the 2016 suburban. Any help/information would be greatly appreciate it as I will be making my decision soon
Thanks!
Nisi in Ky
Nisire is offline   Reply With Quote
Old 10-06-2018, 07:01 AM   #2
2012 19' International
Southeastern MI , Michigan
They’re all mass produced, even airstreams. You’re gonna find things wrong.
A dual axle won’t protect you from blowouts. Only good tires and maintenance will.
Suburban will pull most airstreams just fine.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 10-06-2018, 07:10 AM   #3
2018 25' Flying Cloud
Marana , Arizona
Check out Escape Trailer Industries. Very high quality; I’ve had two.
Rich & Mary
Marana, AZ
2018 25’ FC/FB
Zardoz is offline   Reply With Quote
Old 10-06-2018, 07:14 AM   #4
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Going across a lot of open ground, I’d be concerned about ground clearance. You can usually go to a larger wheel and tire (depending on AS model you choose). Plus there are lift kits available for an additional 3” of clearance. Some models have the dump valves hanging pretty close to the ground behind the rear axle.
I’ve also read more than a few posts about cabinets and wardrobes falling off the walls or coming apart. We’ve had good luck with ours, once again I think it’s model dependent, and of course how fast you go through the rough stuff. I certainly wouldn’t put AS in the “indestructible” or way out there adventure ready category.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 10-06-2018, 07:15 AM   #5
With a double axle though, I have three other tires to rely on. I am looking at a 25 foot flying cloud. I can tell 7500, it is 5500. Thoughts?
Old 10-06-2018, 07:16 AM   #6
I have, I am in Kentucky and there is nothing on the eastern side of the continent. Everything is on the western side and to get one I would have to drive out there and bring it back. If they bring it it is three dollars a mile !!!!!
Old 10-06-2018, 07:25 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've driven my 20' and 25' FC on farm fields with no problem. Common sense rules.
BTW, We just brought this boy home from Montana a couple of weeks ago
2012 Dodge Durango Hemi/AWD
Old 10-06-2018, 08:09 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You have already answered your question, just sitting there on the lot!
Old 10-06-2018, 08:11 AM   #9
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
If it was me, I would look at Nash travel trailers. Very well built and designed for a bit of off-road use, affordable and long lasting.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
Acheron2010 is offline   Reply With Quote
Old 10-06-2018, 08:52 AM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Price a lift kit into the cost of the Airstream if you go that way. It'll give you another couple inches clearance without much in the way of downside.
I have driven a very much stock 30' Classic through a (harvested) corn field. It worked fine and noting was damaged. There was a bit of mud to wash off. There are also a lot of rally held at grass fields. People seem to still go to them.... As noted above, common sense rules. Scope things out before you get in trouble.
Old 12-13-2018, 06:26 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Suggest you also look at Oliver. Double hulled fiberglass. 22 footer is dual axle.
Manufactured in Tennessee. Very boondock friendly. Repairing a serious ding on an Airstream? Hideously expensive and very few places that can do it right. Fiberglass repair? Find a marina, or a surfboard shop, or a bathtub/shower repair place.
Airstreams are glampers. Do they cost too much? Does dating a supermodel cost too much or is it worth whatever it costs?
Old 12-13-2018, 07:05 AM   #12
MikeandCarol's Avatar
Fair Oaks Ranch , Texas
Many Oliver owners do extensive boondocking in back country areas. They are rugged and would do fine being towed across a field. For fiberglass they are expensive, but if you can afford a new Airstream you could also afford an Oliver. They are mad in Hohenwald Tennessee, just south of Nashville.
2016 Oliver Legacy Elite II #135
2016 Ram 1500 5.7L
MikeandCarol is offline   Reply With Quote
Old 12-13-2018, 07:42 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Four BC's...do they have their own trailer? 😍
We have Shown & Water Trial'd one PWD at a time for 30+ yrs. The most consistent concern...cleaning the AS after the show. Especially if the grounds were less that ideal.
We are retired now...so we have more time for cleaning. 😂
If your mind is made up about an AS, at least get one of the shiny interior models, probably much easier to wipe down with a wet towel. 🥴
Sweet Streams...
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Was this site instrumental in you buying your Airstream? jcanavera Community Polls 149 05-14-2018 09:14 PM
Buying a used Airstream melebe Our Community 5 08-16-2003 05:57 AM
Buying Airstream, need help! jfaucett Our Community 33 08-03-2003 08:24 AM
Buying used Airstream dinoburb Buyer Guidelines 12 12-19-2002 03:31 PM
