Old 03-21-2008, 11:55 PM   #1
1968 30' Sovereign
Poncha springs , Colorado
Brion Ziminski
Hello,
I am new to Airstream and am anxious to remodel my 68? Sovereign. I recently bought the Yacht for $1000.00 without a title and in great shape. I plan to give it a modern look including laminate wood floors and modern kitchen and bathroom. Could someone give me info about their experience relocating the bathroom to the mid section and a rear bedroom?
Poncha Lodge is offline   Reply With Quote
Old 03-22-2008, 08:25 AM   #2
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Welcome to the forums and congrats on the new coach. You may wish to try the search function, or a trick I find works is google search adding Airforums to the search string. Lots of good info here on all aspects of referb. Moving the bathroom can be a major undertaking and not for the faint of heart.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 03-22-2008, 08:52 AM   #3
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Originally Posted by Poncha Lodge
Hello,
Fortunately your trailer is large enough to where you might have many options. Start by looking at the window layout, and see where the new bathroom would be. Then, keep in mind that a bathroom needs a tank (s)underneath, and make your design based on that.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 03-22-2008, 10:44 AM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
My advice is not to spend a penny more until you have the title. Until you do, it doesn't belong to you. End of story. Harsh, yes; what you needed to hear, absolutely.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-22-2008, 11:04 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Howdy Brion -- Welcome to the Forums! http://www.airstream.com/docs/weights-1.pdf doesn't give your trailer's load capacity (subtract dry weight from GVWR). Maybe you have a manual? Otherwise I'd guess about 1000 pounds. Be attentive to original weight and how much weight you put in with your remodel. You might get by with increasing the dry (or curb) weight by a couple hundred pounds.
Assuming it was never totaled in an insurance loss, states have their own unique ways of licensing/titling old trailers where the title might have been lost. You'll need to talk to your DMV. And yes, the VIN is ultra simple. There should be a small VIN plaque to the right of the entry door. See VIN samples at the upper left, lines 2 & 3 of this page. Also see http://www.airstream.com/docs/pre1980vin.pdf. You might need to print out copies of both pages to convince DMV about the VIN format.
Royce mentions searching with the Google method. See http://www.airforums.com/forums/f138...rum-37729.html.
Specific topic areas are at http://www.airforums.com/forums/. With this site's search function you can get better results if you use advanced search, use only one search word and specify which subforum you wish to search.
That's not the final answer -- I haven't seen one of those yet. Keep asking questions!
5 meter Langford Nahanni
