Old 08-05-2006, 10:43 AM   #1
GD
2007 27' Classic FB
1960 17' Pacer
Bozeman , Montana
Bowen Water Heater
During my recent vacation, my Bowen water heater blew out. The problem orginially started when I was not able to light the water heater with the pilot and had to use a lighter on the burner when I switched from pilot to on.
Anyway, on vacation, I was using the water heater and when it cylced while my wife was showering the water heater pretty much blew up.
I took it to a RV service center and they indicated that there are no parts for the water heater. I then found a Bowen water heater on Ebay with the same model number.
My question is, can the parts such as thermocoupler, pilot, etc be switched from the Bowen water heater I bought to the one in the trailer. The tank is in good condition, and if I don't have to switch the water tank out, I would be much happier.
Glenn
gduff is offline   Reply With Quote
Old 08-05-2006, 11:23 AM   #2
1976 25' Caravanner
Campton , New Hampshire
Several years ago I replaced my heater controls . Mine is a '76 Bowen , model G10B. Not sure if they are the same but I suspect that they are.Anyway here are the numbers if they help.
Main control = Robertshaw unitrol R103RVTS pn 80-8402
pilot assembly= pn60-8494 ( also 91603)
burner = 92615
pressure relief = 80-8402
It was about 150 bucks for the above . Good luck
PS bought them thru a generic RV dealer
ticki2 is offline   Reply With Quote
« greetings | Top | flyer »
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Bowen Water Heater 61BambiCanada Water Heaters, Filters & Pumps 2 08-14-2004 07:00 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
