Old 08-16-2007, 01:28 PM   #15
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
You should be able to avoid the use of the generator if you practice electrical conservation when dry camping. Using few lights, lower wattacge lights (5W instead of 10W that come in the CCD overheads), or adding LED alternative to a few key fixtures. Ading solar panels would be even more benificial. However, none of these solutions are going to help you if you need to run a hair dryer, toaster or coffee pot. Some have made mounts to attach a generator (or two) to the a-frame of the trailer, just behind the LP gas tanks.
Also, If your in Summit County and want a good place to stay, relatively nearby to Kremmling is Williams Fork Reservoir. You can easily get a trailer into the campground on the east side of the reservior and your camping right on the water! Not sure if you'll have time to do this before you leave. Also, why go I-70 down to Denver and up I-25 when you could just go North towards Steamboat and meet I-80? It would be a MUCH prettier driver and less stressful than I-25. Advice from an Ex-Summit local.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 08-16-2007, 05:35 PM   #16
Kansas City , Missouri
Thank you, Westfalia, for the advice about heading north towards Steamboat Springs. Having not traveled that way we don't know how driveable the connecting roads would be, or our abilities. As I see it, we'd have to take 9 to 14 to 127 before hitting I-80. Is that the way you recommend?
lyrikel is offline   Reply With Quote
2003 CCD International J Goertzen 2002 - 2005 International 3 08-20-2007 02:46 PM
2003 International CCD Pahaska 2002 - 2005 International 5 10-27-2006 10:37 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 04:34 PM
Signature Banners spaceghost65 Our Community 11 10-29-2002 01:40 PM
The CCD vs the AS Pahaska Our Community 2 06-11-2002 03:47 PM
