Old 11-16-2012, 11:50 PM   #1
2010 28' International
2005 30' Land Yacht 30 SL
Moose Jaw , Saskatchewan
Bent front corner panel
Due to a slippery street , I jackknifed my trailer and bent the front stone guard ( will replace it) also the metal under it , any advice to pull or bend it back out , it is depressed about 1 (one) inch
Popcornkid is offline   Reply With Quote
Old 11-16-2012, 11:53 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Welcome to the forum.
Hi, I would try to pull out the dent with suction cups, first. Depends on how bad it really is.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-17-2012, 04:50 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
There are the large glass handling suction cups that sometimes work. If there is a crease, it may not pull. If it is just pushed in, it may pop. Dent King a brand of puller that uses a hot melt adhesive to stick the cup to the metal, so you can generate a little more force. I have used it to pull some hail damage. Paintless auto repair people might make a small hole on the inside panel and push it out with some of their special tools.
Old 11-17-2012, 06:12 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It sounds like the panel dent will be hidden by the stone guard. So try the non-invasive solutions mentioned above, and then just live with the results. Only you (and those who read this thread!) will know it's there.
Old 11-17-2012, 08:54 AM   #5
Thank- you all , I'll look for the Dent King tool.
