Old 08-30-2007, 08:56 PM   #15
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Originally Posted by clancy_boy
Actually - unless you have hunted bear at close range and have shot a predator that can kill you as easily as you can kill him than you should re-think your choice of loads. I would tend to lean towards 00buck - wider pattern - lots more pellets to hit vitals and easier to aim while you are shaking so much. This goes for the two legged type of predators too.
Trust me, I agree completely with Rodney on this one.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 08-30-2007, 09:13 PM   #16
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Bears at Lake Tahoe
Should you care to take the time to read my review on Sugar Pine Point you will see a bear in one photo at the campsite. We were there for 12 days and this critter would check out the area at all times day or nite. This one was not aggressive altho the ranger indicated that there was a real problem in the day use area across the street. So much so that the bear might by now have reached "room temperature". When I checked in I had to sign a thing that said I was aware of bear activity. These guys just can not control themselves- so put your stuff in the bear lockers! The bears really go after the dumpsters tho!! And if you make lotsa noise they seem to go away. I think it's a felony to discharge a weapon in a Ca. state park, another rule I will completely disregard if needed. DG
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 08-30-2007, 09:41 PM   #17
Royce's Avatar
Originally Posted by doorgunner
Should you care to take the time to read my review on Sugar Pine Point you will see a bear in one photo at the campsite. ... DG
Great photos DG. Google found the post in one try.
http://www.airforums.com/reviews/sho...ct=200&cat=all
AIR# 3913
Old 08-30-2007, 09:48 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That looks like a young brown bear.
They are not a problem.
Look out for Mom!!!
Richard
Old 08-30-2007, 09:51 PM   #19
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
geez Richard;
you're pos ta say "that looks like a 86 thirty two foot excella!
I think the black bear is the one in the Tahoe Basin.
www.popasmoke.com
YETI ( 65 Quart )
Old 08-30-2007, 11:09 PM   #20
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
I'm surprised no one has yet suggested pepper spray to defend against bears making entry while you are inside. They sell bear strength pepper spray in many sporting good stores now, and I think it is legal to have this in your possession in the US (but not in Canada).
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 08-31-2007, 12:07 AM   #21
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Yes, it is legal in the US in most locations.
(NOTHING is legal everywhere...)
Dave
Fyrzowt is offline   Reply With Quote
Old 08-31-2007, 08:03 AM   #22
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Originally Posted by Batch
We are newbies awaiting delivery of our 2008 23' Ocean Breeze International, and we'd like to know if anyone has had problems with bears trying to break in when they smell food. If so, what's the solution?
Thanks.
The Batchelors
Reno NV
The solution is to sleep outside on the ground.
Or, park your trailer over a spot where grease has been poured on the ground.
Bozeman Montana Local News
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 08-31-2007, 08:14 AM   #23
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I will carefully wade back into this discussion and leave personal beliefs out, so I will stick with facts that I have been taught. Most Bass Pro shops sell and will give you some training on the use of bear REPELLANT (that's what it is) and the one I purchased mine from allows you to discharge water filled devices for practice. This can be a good thing as you only have 3 seconds of spray in the can and need to learn the proper method of discharging the spray.
(1) One point I remember is that the spray should never be discharged inside a vehicle (I take that to include a trailer) or structure (that would be a tent, too). You will never be able to remove the smell or the chemical agent from the space. You also stand a good chance of getting some on/in you and that would not be a good thing with a bear around (now angry).
(2) You should (flame here because if the situation occurs you are not going to check) try to avoid the possibility of getting this stuff on you. Having been maced (you have to if you carry) - the bear repellant is 10 times worse and has stuff in it that normal mace does not have because of its intended target. BTW - in a pinch this would work well against a two legged animal just as well, you may just have to explain why you used such an inhumane method in court. Nasal constrictors, blinding agents, it causes uncontrolable foaming of the mouth and swelling of the eyes - none of which you will enjoy.
As I was instructed in its use, this is a method of last resort. It is intended to place a barrier between you and the approaching bear (not one in your canp or at you trailer door but one coming for you). The instructor that I had, advised us to leave the area if at all possible, this is not an offensive weapon to chase a bear away from your camper while you place yourself withing range of the bear to apply the spray.
The numbers that I have seen show the spray to be about 80% effective on charging bears but that number drops to 45% effective with charging female bears with cubs. Nothing like a mothers protective zone.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-31-2007, 08:48 AM   #24
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
The fact is, pepper spray is not needed in dealing with black bears. Loud continious noise will discourage a bear trying to gain entry. Belive me, it really will. I wonder if I ought to write up an article for the forums about black bears this winter. If there is sufficent interest and I can fit it in I will consider doing so, but I dont want to go to the effort if there is no interest.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 08-31-2007, 09:08 AM   #25
2002 25' Safari
Dewey , Arizona
Images: 62
When fishing in bear country (Northern Canada) the recomended method of getting bears to move on was banging the oars aganst the sides of the boat. Load noises will work in most cases. When hiking some people will attach bells to their shoes just to make alot of noise as they go along. One of the worst situations you can get into is when you surprise a mother bear who is with cubs. This will cause the bear to defend her cubs. If they hear you before they see you, they will move away.
Richard
Old 08-31-2007, 09:24 AM   #26
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
In thinking about this it is tremendously important to distinguish between black bear and grizzly bears. Behaviorally, they are quite different and your approach to dealing with a bear should be predicated on the knowledge of which species you are in contact with. For the most part this thread has dealt with black bear since that is the species the average traveler is most likely to encounter. Having said that: if you are traveling in grizzly country, a whole different set of rules of interaction apply. Be a smart traveler and educate yourself before going into bear country.
Rodney
and the
My Blog
Old 08-31-2007, 09:57 AM   #27
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I try to keep a close eye on my beer...no intruders are allowed.
Unless of course they are fellow Streamers'
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 08-31-2007, 11:00 AM   #28
Happy Trails
bhunt's Avatar
2005 16' International CCD
Delaware , Ohio
Perhaps most revealing is that, so far, nobody has a story of a bear peeling off the door or ripping a hole in an Airstream. More than anything else, this seems to say it's very unlikely. I'll wait to hear someone with a solid harrowing story of bear attacking AS before I want to take this whole issue very seriously.
bhunt is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
