Old 09-09-2011, 08:21 PM   #15
1993 19' "B" Van Airstream 190
Albuquerque , New Mexico
Okay...we finally have some answers! My husband took it to some suspension shops yesterday and it seems like the van needs some "front end work". So, we took it in today and had new upper and lower ball joints and a new control arm installed. We also talked about air bags and they said the front anti sway bar was okay but that it could use a back one. At this point, it is now safe to drive and I will be hauling a friend and our 2 horses to Santa Fe tomorrow for some camping and a competition on Sunday. I did notice an improvement when I drove the van home...it swayed a lot less. I guess the tires were NOT the problem as I originally thought. We will look at upgrading some of the other things but at least I know it is now safe and roadworthy. Thanks for all your help and I'll keep you posted...Trisha
tlcinvest1 is offline   Reply With Quote
Old 09-10-2011, 09:11 AM   #16
Lily&Me's Avatar
Normal , Illinois
Be sure, too, that all your heavy things are in your bottom cabinets/storage areas.
Also, distributed as evenly as you can front-to-back and side-to-side.
Safe travels,
Maggie
Old 09-10-2011, 01:25 PM   #17
Yes, I try not to put heavy things in the top cabinets. The alignment guys said that the van is very heavy in the back b/c all the tanks are back there. There's not much you can do about that unless you fill your fresh water at your destination. I'm off to Santa Fe (from Albuquerque) and will let you know how things went when I get back...Thanks! Trisha
Old 09-10-2011, 01:56 PM   #18
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Uh, check the max weight rating on those tires (should be embossed in the side). The rear axle has about 6,000 lbs sitting on it, so the tires need to be able to support that. The stock tires handle about 3,000 lbs at 80 psi - I don't know what the new ones have. I'm guessing they have enough capacity or you would've shredded one by now, though.
Definitely sounds like you have the steering issues resolved (or will soon). They're a top heavy vehicle, so it's going to feel a bit sloppy compared to a car, but at the same time it shouldn't be too much.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-11-2011, 06:54 PM   #19
Has anyone heard of Timbrens? One shop recommended them. I drove the van to Santa Fe pulling a 2 horse trailer (full) and the van did much better so the work they have done so far has made an improvement....Trisha
New owner had 3 questions LindaM Land Yacht/Legacy Motorhomes 6 05-23-2017 07:23 PM
New AS Owner - General Questions MoDrifter Bumpers & Bumper Storage 9 04-04-2011 04:14 PM
Potential New Owner and Questions RV Doctor Member Introductions 24 04-01-2011 07:10 PM
Floor Questions ranns ammee Repairing/Replacing Floor &/or Frame 15 02-05-2011 09:45 AM
