Old 12-11-2006, 11:09 PM   #1
Anacortes , Washington
Aluminum gauge
I just bought a 1963 Safari and need to replace a panel. Since the only stupid question is the one unasked, what is the gauge of the aluminum on the trailer?
Thanks, Mike
mherbert is offline   Reply With Quote
Old 12-11-2006, 11:20 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Should be 0.032
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 12-11-2006, 11:25 PM   #3
Images: 70
BTW - Welcome to the forums
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 12-12-2006, 12:35 AM   #4
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
2024 T3 All-Clad?
Michelle TAC MT-0
Sarah, Snowball
Old 12-12-2006, 02:15 AM   #5
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Originally Posted by thecatsandi
2024 T3 All-Clad?
yep. when i reskinned my 18 footer, that's what i used. i used .040 on the door and some of the panels to stiffen things up. it doesn't oil can as easily as the .032. don't use any other alloys on the skins. they'll never buff out the same.
good luck! got your clecos and rivets?
jp
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 12-12-2006, 07:21 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Mike-
Welcome aboard. .032 was the standard at the time. Wether you stick with this or go up a grade is fine, the big problem is always getting the material to match after buff and polish. I suggest that if you can get a small piece from your supplier first, run it through the polishing process you use on your Safari now and check the sheen and color to match. If it matches, then purchase your sheets.
Good luck and send pictures.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-12-2006, 10:00 AM   #7
Thanks for the info. This could be a long project. I'm a brunt for punishment.
I also have a 45' 1941 wooden boat.
Mike
Old 12-12-2006, 01:11 PM   #8
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
which panel are you replacing?
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
