Hello All,
I am in the breaucratic process of purchasing a 1977 31' Sovereign from an estate. I'm hopefully going to be able to pick it up late this week and get it ready for my vacation next week...nothing like waiting until the last minute right! It needs a little cleaning, and general repair but it's in overall good condition (I think) I have a general question for anyone that happens to read this. I have an 02 HD Chevy that can drag a house (without wheels) down the road. (That was supposed to be a joke!) Anyway I am used to towing the 25' horse trailer with 4 horses down the road. The airstream is 140 miles from home, I've made the trip before with a 16' uhaul. My concern is that it is a 90% interstate drive, and I know nothing about this trailer other than what I have seen, so I'm not sure what to expect while towing it. It's significantly larger than the horse trailer, but it is about the same weight or lighter. When I was talking to the woman about purchasing this she said that there was a problem with the frame and needed repaired before it would pass inspection and that someone told her that it could be safely towed at 25mph. I thoroughly looked over this trailer and the only thing that I could find wrong with the frame is that on the back bumper where they have a bike rack attached it has rusted through, broke off and is only holding on on the left side. I figured afew bungie cords would hold this down to get it home to repair it. The rest of the visible frame in the back was solid, with moderate rust, but there were no problems. So to finally get to the question is....is there anything that I should really check out before heading home, and what can I expect for the drive? The last time the trailer was moved was a few years ago. Also, I've read that driving without the brakes hooked up is hazardous to your health. I do not know what sort of brakes this has on it, but they might not be working to get it home...is this a huge problem? I will have it fixed when I get home where resources are a plenty.
We have done a few shows on traveling to get a trailer, and you should give them a listen. Why don't you just cut the bumper off, to save you the grief of wondering if it is still holding, and if you don't, I'd use ratchet straps. I'd be less worried about brakes, if it is 90% Interstate like you mention, but more about the tires. Just take it slow, and you'll be fine. Any pictures of this montrosity?
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
Past President WDCU
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
This unit may have the disk brakes that are vacuum operated, if the previous owner did not change them. To pick it up and have the brakes work you would have to install a vacuum line from the manifold back to the rear bumper of the TV. Not practical as you are likely to abandon these brakes for electrics if you follow the lead of most other 77 owners. If the gound is fairly flat to the pickup place and back I would not worry. Check for dry rot on the tires. You can easily do $1000 of damage when one of them blow. New tires will be needed anyway. Go a day early, take the wheels off and have the tires renewed. Look carefully at that rear frame to make sure it has not started to droop. 77 31's are famous for that and it will cost you $2000 to fix it. Also check for bulges on the side of the trailer that is another sign you are in for big money ($2,000 + )to fix the frame.
Bearings should be repacked and make sure the rubber is good
__________________ "If a man does not have an ideal and try to live up to it, then he becomes a mean, base and sordid creature, no matter how successful." Letter to his son Kermit, quoted in Theodore Roosevelt by Joseph Bucklin Bishop, 1915
I'd like to chime in as I just got a 78 Sovereign. Can I buy a "generic" brake controller like Tekonsha and use it with the electric brakes on this trailer? Do I care if I have one I I am not doing a lot of mountain ( but some) towing?
I don't yet own an equalizing hitch, other than the old bars that came with this rig, should I use these or invest in newer? I can sell the stowmaster tow bar from my moho toad to help pay for this stuff.
Lastly (for this go round), as I am used to filling the permanent mounted lp tank do I pull off the tanks and take em in to get filled or do you leave them while mounted when pulling the trailer?
Rallys twice a year..Lots of fun, food, and aluminum.
I'd like to chime in as I just got a 78 Sovereign. Can I buy a "generic" brake controller like Tekonsha and use it with the electric brakes on this trailer? Do I care if I have one I am not doing a lot of mountain ( but some) towing?
Alan, congratulations on your latest obsession, er, project. We have Tekonsha Voyager controller for ours, and it works very well, it was about $70 or so. As long as the old WD bars are suitable for your tow vehicle, and not excessively rusty (as in rotted out) there is no reason not to use them, at least in the short term.
As for the tanks, I have always pulled mine off, and taken them to be filled. It's usually, but not always, cheaper to take them in, than have the LP brought to you.
All this talk of blown tires and a damaged frame is making me ill. The tires were put on about two years ago and it wasn't ever used. I hope they are good enough to make it home. They looked great to me, they have more tread on them and less cracks then the new ones on my car. I was reading up on frame seperation and most of the forums talk about 31'ers with the bath in the back, mine has the bath in the centre. Since the bumper is 1/2 broke off I can't really do the bumper test. Would the rusted off bumper where the bike rack connected be any sign of a bad frame, or just neglect at a weak spot? I don't remember seing any buckels on the sides or any apparent sag in the back, this will have to wait for further inspection. How does one repack the bearings? Is this something that can wait until I get it home or is it imerative that it is done before I bring it home? My resouces are very limited in the area I am picking it up in so the least I have to do there the better. Thanks again.
Okay, to help put perspectiver on a problem with your coach that may or may not exist, you coach would be the easiest one to repair if it does have frame and floor rot in the rear, as you would not have to do anything but pull out the bed and maybe some cabinetry, no plumbing. If the tires are only two years old, you should have no problems with them, just make sure they are properly inflated. It would be a very good idea to have the wheel bearings repacked before leaving with it, and you will be able to see what condition the brakes are in at the same time.
Repacking the bearings is not hard, if you have ever done this on your 1968 Chevy pickup with drum brakes, you have the skills to do this.
A mid-bath rear twin is the easiest model to check for rear rot on. The beds tilt up and you can see the floor. You can see the floor through the aft streetside compartment door, too.
The test of looking for skin crinkles just behind the rear wheel is not too useful on a 31, however. They are easily indicative of a tail drag event. Would that be how the bumper got partially broken off?
I also removed a 50 lb bike from the back of mine. (Why tempt things? It was just so much more weight hanging out the back.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
We have a 31ft 75 model with the center bath and you can check under the beds for rot. Like the others have stated you have to be veryyy careful with tail drag we found that out last camping trip. We have a 03 truck like yours and I also have pulled many many horse trailers. When you pull the Airstream it's a whole different feel. Ours is so smooth and with sway bars and a good hitch you don't even know it's there.
__________________ Becky 75 Sovereign (Peppy) 03 Chevy HD (lil Peppy) Air# 9552
Nope, never done this...The truck is an 02 and still under warranty! The extent of my vehicle skills is changing the brakes.
Mine has a queen/full bed, how's checking for rot and a bad frame with this layout?
What are sway bars? Laying on the floor there are some extra bars and a strange hitch. I assume this is some sort of sway control?
At any rate, it doesn't look like I will get to spend my vacation next week in the camper, but rather working on the camper! Oh well, atleast it will be ready for use.
Attached below are some pictures. A few of the outside, one of the rust damaged bumper, and one of these sway bars.
Well, it looks like you have a Reese Dual-Cam hitch setup on the trailer, and those are the lift bars. Usually the seller will include the forward part - the mount and actual hitch that plug into the receiver.
thread shows what the hitch parts look like, and post 11 shows what it looks like when hitched up.
Bike rack BAD. I took one off of my '79 and was really surprised at how heavy it was.
If you open the rear side compartment, I think you can get to the floor there. Other places to check include under any window that may have been leaking, around the battery boxes, around the toilet, around the water fill, around the water heater, and around the water inlet.
It looks about time to replace the carpeting anyway, so that'll give you great access to inspect the floor.
Looks like the shell is nicely intact. (Mine has dents and waves).
By the way, you DID get this trailer to have something to work on, right?
Lamar
Klaatu barada nikto
Lamar
The bike rack was the first thing to go in the big clean out. Followed by the carpet. The floor in this was fairly good. The only bad spot that I could find was all the way in the back. I replaced it in about 1/2 a day. The rest of the floor is great. The shell is in decent condition, there are some scratches on it, but nothing major. I didn't set out to buy one to work on but, the price was right and the condition was fair. It doesn't really have anything severly wrong with it, just some things here and there that are to be expected with a 30 y/o trailer.
I did replace the carpet in the front and back, and also put some laminate in the kitchen area. I was amazed to find that the orange fabric on the couch was in perfect condition.
