Originally Posted by zanad
say, you wouldnt know where and how to do an easy patent?
just wondering
It is not an easy process and one I would not recommend trying yourself. I am in the process right now and have found it is best to find a really good patent attorney. The trick to getting a good patent that others could not steal, variate, or duplicate is all in the verbage of the statement of device. If you go to the patent web site you can read many of the patents on file and you will see that the verbage is very broad. ie: the spar arm is connected to the fly arm with a fastner. You would never say, the stainless steel spar arm is attached with a 1/4" nut and washer. If you did someone else coud file a patent changing the 1/4" nut and washer to a 3/8" and the stainless steel spar to a RD90 steel.
