Old 10-02-2007, 01:46 PM   #1
Anton66's Avatar
1966 17' Caravel
Sarnia , Ontario,
A newbie question
Hello all. I've just purchased a 1966 AS Caravel. Its in need of a lot of work, but I'm in no hurry and I want to just take my time and do it right. I've been able to answer most of my questions by searching the forums, but I have one that I'm still not sure about. I need to remove one section of the interior vinyl wall (which is held in place by rivets), how do you remove the rivets? Someone at the local hardware store said to drill them out, which I tried with no success. Any suggestions?
Anton66 is offline   Reply With Quote
Old 10-02-2007, 01:51 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
You drill them out. Use a very sharp drill bit and center it on the rivet hole. You will be shaving off the outer collar and the rest gets pushed back into the wall.
When you finish and need another Caravel to finish - let me know....
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-02-2007, 01:52 PM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Get a better drill. That is how it is done. You may want to do a search on the Internet on how it is done. Those must be some mighty tough rivets. I start with a small bit and work my way up. After you do a few you will get the feel for it and can just use one bit and not have to change. Good Luck.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 10-02-2007, 02:31 PM   #4
TSHEP
1978 25' Tradewind
1973 29' Ambassador
Woodlawn , Tennessee
Hole saw. About an inch wide.
Just kidding. Use a cordless drill with a good 1/8 drill bit.
TShep
TShepherd is offline   Reply With Quote
Old 10-02-2007, 02:34 PM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
A #20 drill bit will do the trick for you. Once you have the rivits out you will want to replace them. Check out Vinyage Trailer Supply for an assortment of rivits.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 10-02-2007, 02:48 PM   #6
Anton66's Avatar
1966 17' Caravel
Sarnia , Ontario,
It works
Thanks everyone for your quick replies. I guess I was doing it right all along, I didn't realize the rivet came out the back and falls down, I was expecting the rivet to come out on the drill bit. Also, from what I had read on another thread, can I replace the old rivets from regular ones from Home Depot, or do I have to order the ones from Vintage Supply?
Old 10-02-2007, 03:54 PM   #7
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
rivets
You can use the ones from ACE or Home Depot, just make sure you buy aluminum rivets.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 10-02-2007, 07:03 PM   #8
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Another tip - paint them to match your interior with spray paint and let them dry - then pop them in place. That way you can buy the cheaper un-finished type and save some $$$$.
Old 10-02-2007, 07:24 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums Anton66..and have fun drilling those rivets!
See ya on the road,
TB
Old 10-02-2007, 10:05 PM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome
GOOD LUCK...you should be a 30 rivit member by the time your done.
Keep us posted, and add photo's asap!!!!!
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-05-2007, 09:52 PM   #11
1979 Argosy Minuet 6.7 Metre
Ridgeville , South Carolina
When you do get ready to put the rivets back in, I strongly encourage you to buy a rivet gun with a rotating head. It only costs about $5 more than the fixed head one. Some of the rivets you will replace during your life together with the AS will be in tight spots. This will make it easier and ensure the rivet is put in adequately.
buzzbuck is offline   Reply With Quote
Newbie question about TV jeftec Tow Vehicles 7 06-28-2007 09:17 AM
Newbie Question Pharmdawg Our Community 1 08-19-2006 05:49 PM
Value question from a newbie lebolewis Trailer Values 5 04-25-2006 11:48 AM
Another newbie ID question! kestrel Our Community 2 08-17-2003 05:43 AM
NewBie Question Chitown AirStreamers 1965 Safari 9 05-13-2003 08:27 AM
