Old 04-04-2018, 08:18 PM   #1
1978 Argosy 27
Sayre , Pennsylvania
A Dream Come True
Greetings from North Easternish PA. My name is Joshua and I pastor a Wesleyan church in Sayre, PA. I've always wanted a camper, especially after going to the church's family camp last year with a wife and two very young kids in tow and staying in a tent all week. After looking at an old, broken down camper at the campground, my eye caught the beautiful shilouette of the 1978 Argosy sitting two lots down, and I fell in love. One thing led to another, and we ended up "inheriting" the Argosy from the previous owners. She's dated, but solid. Unfortunately, she hasn't been on the road since 1992, so it's going to take some work to get her rolling again, but at least for now we have a place to stay that's not a tent! As far as I can tell, other than the fridge, everything is original. Any advice on upgrades or recommended maintenance would be appreciated. I'll post pictures of our progress.
ID:	307862   Click image for larger version
ID:	307864   Click image for larger version
ID:	307866   Click image for larger version
Holy_Roller is offline   Reply With Quote
Old 04-04-2018, 08:28 PM   #2
Mc2
Mc2's Avatar
2020 25' Globetrotter
Wayne , New Jersey
Congratulations! Enjoy and good luck with the rebuild
Mc2 is offline   Reply With Quote
Old 04-04-2018, 09:44 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Congratulations and enjoy your trailer! I don't want to scare you, but you asked..... Here are a few maintenance and inspection items for your consideration.
1. Tires will need to be replaced, and maybe the axles. When these trailers sit for a long time, the axles lose their flexibility.
2. Brakes will need to be serviced and adjusted, or it may be less work and not substantially more expensive to just replace the whole brake assemblies.
3. I don't know about Argosy trailers, but some rear bath Airstreams had problems with rotting floors and separation of the skin from the frame. This is easily detected by standing on the rear bumper and bouncing up and down. There should be no relative movement between the rear skin and the bumper.
4. Make sure you have operational smoke, carbon monoxide, and propane detectors.
5. Check, or have someone check, the furnace to ensure that the heat exchanger is not leaking into the trailer.
6. Check the sealant on all penetrations through the skin and replace/repair as necessary to eliminate the potential for leaks that can rot the floor. Probe for soft spots in the floor at the door, storage compartments, and under all windows. If any are found, there is potential for frame rust under them.
I'm sure there is more, but I tried to hit the biggies.
Hopefully you will have none of these problems and your efforts can be confined to cosmetics and decorating.
Al
Old 04-04-2018, 10:11 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well,welcome... right at Eastertide... kewl..
So much to learn... first is running gear.. tires, brakes, bearings, axles...so you can safely move the Argosy... Note that you must have 12volt battery onboard to activate the electric brakes in event of a 'breakaway'..
Once you are able to tow reliably and get to your properly.. check out the floor around the perimeter.. as close to the wall as you can get.. all around.. poke with an Ice Pick... note any soft spots.. that means long term leaks.. and damaged flooring.. you will need to fit...
Next start working on the other 'systems'.. 12 volt, 120 (ac/shore power).. water, waste tanks... and LP system... (be careful with this one especially...)
Anyway, thousands of points you might need.. so, we look forward to specific questions..
Clergy here, too...
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-05-2018, 10:48 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Welcome, Pastor Joshua! And congratulations on your Argosy!
Yes, much improvement over a tent! I'm sure your family appreciates that a LOT!
I look forward to seeing what you do with it!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-05-2018, 12:26 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Welcome aboard. I suggest you look at Penn Woods, an Airstream only campground in western PA, attend a forum rally or two, and consider visiting or joining a WBCCI unit near you. WBCCI stands for Wally Byam camping club international. Wally founded Airstream.
RV people are generally very helpful toward newbies, Airstreamers even moreso, so meeting other vintage owners should be a priority. You can start with a rolling tin tent once your running gear is brought up to safe standards... and then you can go for broke. (Matthew McConoughy or however it is spelled spent a fortune redoing one) use SEARCH with the keyword "contemporizing" to see a drool-worthy Argosy... or "full monty" for other threads that have nothing to do with male nudity.[emoji44]
Old 04-05-2018, 06:31 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hello from Colorado: Welcome to the Airstream community. Your opening comments reminds me of my family. Dad was the Scout Master of our troop and tired of sleeping in a pup tent. He convincienced Mom we needed a travel trailer. So Dad slept in a heated camper and we scouts slept in tents on the cold ground. Maybe that old Shasta 16' got me interested in travel trailers.
Your new Argosy looks pretty good. Like others have said, it will have many needs to be road worthy after sitting for so long. Maybe $1500 in axles and brakes, maybe $250 in tires and a lighting check. You will need a hitch to pull it at maybe $600. It's so much fun spending other people's money.
I bought a 75 Overlander 27' last fall. It is similar to yours but older. I have new axles in the shop waiting for installation. My trailer was in pretty good shape excluding old appliances and some old plumbing problems. I'm making progress getting it "travel ready".
Enjoy.
David
Name:	1709 Colorado Springs Awnings (Small).JPG
ID:	307924   Click image for larger version
Name:	1709 As found gaucho 2.jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 04-05-2018, 06:49 PM   #8
2016 28' International
Sioux Falls , SD
Congratulations and welcome !
You and especially your kids will enjoy the journey.
We are all looking forward to your progress.
Get tires and leaks under control. The rest as you can financially afford. Start with what you need not want.
Best of luck !
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-06-2018, 05:55 PM   #9
Lve42dy's Avatar
2018 27' Globetrotter
Jeffersonville , Indiana
Welcome!
I’m new to AS as well. Haven’t even received my rig yet. I admire anyone who can and has the patience to rebuild.
Please keep us updated with progress. Looking forward to pics.
Lve42dy is offline   Reply With Quote
Old 04-06-2018, 06:33 PM   #10
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Congratulations on your new to you Argosy. May I suggest she should be named Jericho. Exciting times are ahead.
Remember to take care of the safety issues first.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 04-07-2018, 11:06 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Holy_roler... are you done yet? =)
Channing
WBCCI# 30676
A Dream Come True...our 1969 AS Tradewind monah 1959-69 Tradewind 12 06-17-2008 05:39 PM
Dream come true, 1966 Ambassador Gratefulalki Member Introductions 2 04-25-2007 07:03 AM
my dream come true! alumfever Member Introductions 3 09-04-2006 05:11 PM
Dream Come True Rollers Member Introductions 4 03-31-2006 07:35 PM
A dream come true Thanks RichardT kneepie Our Community 22 06-12-2005 07:35 PM
